Help 7.3 96 stranded!! - Ford Powerstroke Diesel Forum
post #1 of 50 Old 04-16-2013, 06:35 AM Thread Starter
Pulled a trailer 60 miles stopped to upload a truck off trailer with a blown tranny. Cranked up went 5 miles down road. Stopped to grab some coffee and go to bathroom maybe sat 5 mins or so. Came back to truck all it will do is turn over!
First thought is cam sensor??? Where is it?
2015 F-350 Lariat SRW CC
Sold to my dad:1996 F-350 XLT Crew Cab
2x4 Dually 7.3 with 80,000 miles as of 3-10-15
YJSONLY is offline
post #2 of 50 Old 04-16-2013, 06:51 AM
nine6stroker's Avatar
Quoted: 35 Post(s)
Do you get a tach reading when cranking? Does the WTS light come on? Any smoke out the tail pipe?
And the CPS is about at the 11 o'clock position above the crank pulley IIRC.
1996 F250 7.3 PSD 4x4 - "Dally"
281k miles
BDP stage 1's, T500 HPOP, TS6 chip, KC38r turbo, stock trans and fuel
Sitting on 2006 F-350 axles and suspension
nine6stroker is offline
post #3 of 50 Old 04-16-2013, 06:53 AM
boozinag's Avatar
If you have a chip try removing it. Are you getting any smoke?
How old are your batteries? 2 members just had similar problems, the batteries were too weak to spin the engine fast enough thus the PCM would not provide any fuel. And you really can't tell just by feel if it is or isn't fast enough.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #4 of 50 Old 04-16-2013, 07:09 AM Thread Starter
Update on the way home. Will be back later.
YJSONLY is offline
post #5 of 50 Old 04-16-2013, 12:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Get it running yet?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 50 Old 04-16-2013, 05:13 PM Thread Starter
Update: I let it sit for about a 1 hour. Tried to read the tach as it was starting and it fired up. Drove home fine about 60 miles. parked it at work (for 6 hours) and would crank and not start. I did not check the tach this time.... I was in a so I left it. But its at work....
So I have a CPS that I am going to put in...... What else to look at?
YJSONLY is offline
post #7 of 50 Old 04-16-2013, 05:15 PM Thread Starter
Batteries are only 6 months old OEM at that... And terminals are clean. No Black or white smoke coming out either the best I can tell... Not chipped either.
YJSONLY is offline
post #8 of 50 Old 04-16-2013, 05:15 PM
boozinag's Avatar
I would've pulled the batteries before I left and have them charged up even though they are new.
Gerry
184k
boozinag is offline
post #9 of 50 Old 04-16-2013, 05:16 PM Thread Starter
WTS light comes on and goes off like it has been as far as time coming on and going off.
YJSONLY is offline
post #10 of 50 Old 04-16-2013, 05:16 PM
boozinag's Avatar
I would also see if you can check the fuel pressure, could not be getting enough fuel.
Gerry
184k
boozinag is offline
