explorer overhead console temp problem - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-15-2013, 08:11 PM Thread Starter
StrokerIH's Avatar
i installed a explorer overhead console and everything works great except for the temp. its reading 30-40 degrees low (F and C). any thoughts as to what might be the problem? thanks
97 F250 HD, XLT, ext. cab. long bed, 4X4, E40D, 3:55LS, 3" DP, 4" MBRP, 5 1/2" tip, No Cat, No Muffler, E-Fuel, TS 6 pos chip, Front add-a-leaf, CAI 6637, Marinco Block Heater Plug, 265/75r16 transforce a/t, custom made mirror extensions, door keypad
StrokerIH is offline
post #2 of 13 Old 04-15-2013, 09:04 PM
Quoted: 8 Post(s)
I would love some suggestions here as well. I have been having all sorts of problems with the temp. Reading low or just taking one reading and never updating. I have changed the temp sensor several times.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #3 of 13 Old 04-15-2013, 09:32 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
a couple things could be wrong here, it is either wired backwards or your computer in the ohc is bad
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 13 Old 04-16-2013, 11:56 AM Thread Starter
StrokerIH's Avatar
i tried switching the wiring around didnt change anything
post #5 of 13 Old 04-16-2013, 12:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
May be the mother board, did you use the same size wire as the original stuff?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 13 Old 04-16-2013, 08:16 PM Thread Starter
StrokerIH's Avatar
im not for sure i will have to look ...it might be a gauge heavier of wire
post #7 of 13 Old 04-18-2013, 07:26 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 121 Post(s)
Could be a bad module or sensor giving the inaccurate reading. Rumor is that if the VSS wire is not connected the temperature will not update, since the module thinks the vehicle is stationary and getting heat soak from the radiator.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #8 of 13 Old 04-18-2013, 10:22 PM
joedown's Avatar
Are you certain you actually have the right sensor?
96 F350 4x4 XLT 7.3 59,428 orig miles, Stage I's, Adrenaline, IDM, gutted EBPV, Tymar intake, Banks intercooler, downpipe, gauges, TW 4 position chip, John Wood Towmaster, Ford 08 diff cover, Oil gauge mod, Electric fuel conversion, RSK, OH console, Durn cat done run off an I can't find it.
It is better to have a lobster on your piano than to have a crab on your organ
joedown is offline
post #9 of 13 Old 04-19-2013, 01:58 AM
birdco85's Avatar
That makes total sense! I've been wondering why my temp won't update! That has been bugging the cr@p out of me. Do you know which wire is the vss?
1995
F350 PSD, 4x4, CCLB, Auto, 236,xxx, Tymar, 4" Diamond Eye, PHP FU2 chip, T-500, Rosewood Stage 2.5's, DIY E-fuel, Intercooler, Gauge's (Pyro, Boost, Trans), CCV Mod, Explorer OHC....way more to come.
birdco85 is offline
post #10 of 13 Old 04-19-2013, 06:04 AM
Electrical Ogre
Quoted: 121 Post(s)
The VSS wire is gray/black on both our trucks and the OHC.
Access it behind the instrument cluster.
Bill
2008 Ranger SC FX4
