towing? 1996 w/ 5spd
I have a 1996 f-250 with a five spd and 4:10 gears. I have yet to tow with the truck so I want to ask. how is it with that much gear? and how are the non-intercooled 7.3's at pulling? I have a superduty intercooler I plan on installing on the truck when I get the time.
I'm used to towing with my old 6.0 Ross |
with a 5 spd and 410s your rpms are going to be fairly high at 70 mph, iirc my buddy runs 2400-2500 with that combo. The non intercooled do ok, but adding an ic makes a nice difference.
how much of a diff would you notice with the cooler?
Hi RLSVT! Strange seeing NLOCers over here!
Yeah tell me about it. I don't know what's in mine, but I'm running 2500 rpms at around 62mph. |
i run about 1950 at 60-62 and about 2200 at 65 -68
with my 4.10s I run about 2,050 rpms at 60mph
I like to tow around 70 so what do you guys think the rpm will be if I changed to a set of 3.55's of 3.73's.
With stock injectors, i doubt you'll notice a huge power difference but it will drop your egt's alot which will help pull the hills better.
my dad says towing with 4.10's should be fine
Towing alot id go with 373's if you can get them for that rear end. We've got 373's in our superduty tow truck and its a great all round gear choice. 355's are good to tow with on the hwy IF you have enough power to make up for the taller gears.
