Battery cable wire size - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-15-2013, 10:31 AM Thread Starter
mkeith54's Avatar
I need to know the optimum wire size for the positive battery cable. I'm ordering the supplies from McMaster Carr to make the cable. Will be using solder on ends and middle terminal along with heat shrink and epoxy under the heat shrink to water and acid proof the connectors. Thanks.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #2 of 7 Old 04-15-2013, 11:16 AM
JBRIXEN's Avatar
IIRC they are 2/0
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #3 of 7 Old 04-15-2013, 11:20 AM Thread Starter
mkeith54's Avatar
Excellent, that is what I what I was thinking that or 1/0. Going to use welding cable to make it easier to flex. Thanks!
Mike Keith
New Florence Mo
mkeith54 is offline
post #4 of 7 Old 04-15-2013, 11:43 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
if your going to replace the positive cable to a larger wire, I strongly suggest making the ground the same if not larger
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 7 Old 04-15-2013, 12:00 PM Thread Starter
mkeith54's Avatar
I'm looking 2/0 or 3/0 right now, there is only 50 amps difference between the capabilities of the two but I think I'll go with the higher of the two. I'll have to measure the cross radiator channel to see what is the largest size I can use. McMaster Carr has the solder on terminals and connectors. I'll probably color code the wiring red for positive and black for the negative.
Kris, I'll definitely keep that in mind It'll be at least the same size, larger if the routing will allow it.
Mike Keith
New Florence Mo
mkeith54 is offline
post #6 of 7 Old 04-15-2013, 01:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
messing with these is kinda like stereo, if your ground is smaller than your positive it will have adverse effects, so I always make the ground larger than the power wire when I do stereo, or battery cable changes
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 7 Old 04-15-2013, 01:35 PM
Term3's Avatar
Quoted: 2 Post(s)
Agreed, pointless to increase the positive side if you don't upgrade AND clean both grounds. Make sure you use some conductive grease. Here's my upgraded cables that are made from Royal Diesel Locomotive tinned cable which is excellent in corrosive, wet atmospheres (If you've ever had to replace the plug on your block heater cord you know how corroded bare copper gets, even further up inside the insulation jacket). Still want to add better battery clamps.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
