how to get to blower motor
of course its cold here in Pa. and my blower motor for heat and A/C went out. how do i get to it to replace it, where is it. do you guys have step by step how to do it. or is this something i should get a manual for???
its ok now, but when i get up at 3 am to go milk cows its a little cold getting in the truck at 20 degrees. ![]() thanks |
bump. heat needed. ha ha
Did it just simply quit blowing? make any noise before it quit? If not check the fuse.
it just stopped. i checked the fuse it is good.
what i would like to know is where is the blower motor located, easiest way to get to it. i suspect it is under the dash, i took a quick look under there and YIKES wires allllllll over the place. |
still no heat. i cant find anything
hold on let me check for you.
ok mitchel shows engine compartment on the passenger side at the firewall. Shouldnt be too hard to get to.
if u can get to the plug i would hot wire it just to see if it works
Matt |
he should be able to do that the plug is in the engine compartment and doesnt look hard to get to at all.
ok thank you guys i got it in, with a little elbow grease. next problem it is till doing the same thing, just letting a little heat in through the vents. is it the resistor?? if so how do i get my hands on a resistor??? i tried a couple of diffferent auto parts stores and they dont carry them. is it a dealership item???
