Might as well have some fun with this... - Ford Powerstroke Diesel Forum
post #1 of 19 Old 04-14-2013, 09:38 AM Thread Starter
PSDprepper's Avatar
So my pride and joy got hit yesterday as I was driving home from my shop. Some guy in a uhual decided to cut into traffic just as soon as I was goin' by...
Luckily he had insurance.
SO... I was thinking, I'll just get her fixed back to normal and be on my way.
OR see if the insurance will cash out, and I'll get a bradford built flatbed and do a dually swap along with a zf5 at the same time, and use my saved up money to throw a sky SD shackle reversal under there... Im thinkin that would make for a pretty badass truck. But is it worth all the work and money?
I don't know a whole lot about duallys, what are my options lifting the truck, what kind of tires I can use, how easy would the swap be, can I still have 4x4, etc...
So tell me what you think I should do...
- Tyler
PSDprepper is offline
post #2 of 19 Old 04-14-2013, 10:35 AM
erics diesel's Avatar
Ouch glad it only damaged the box
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 19 Old 04-14-2013, 10:38 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Glad your alright and it was only the box!! Time to have some fun!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #4 of 19 Old 04-14-2013, 10:55 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Glad your ok, as far as a dually swap, your going to need 4 rims if your not doing the front, and 6 if you are doing the front, some options are adapters for front, or dually hubs, and spacers for the rear if you want larger tires, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 19 Old 04-15-2013, 05:50 AM
Lift is easy but to get bigger tires gonna need spacers for the duals and i would suggest finding a actual dually rear axle and using hubs up front some say spacing things instead of the proper parts will reduce payload on the truck
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #6 of 19 Old 04-15-2013, 07:43 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
is yours a proper dually axle ben? I thought all the conversions were srw originally and spacers added front and rear? do you have dually hubs?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 19 Old 04-15-2013, 08:20 AM
Quoted: 54 Post(s)
Bed off, good time to swap to a larger rear tank....
madpogue is online now
post #8 of 19 Old 04-15-2013, 10:22 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I agree with ben... find a dually rear axle to swap in. When u find that, remove the front hubs off the front and install them on your truck. U will need 6 rims and to use 35s, u will need 2" wheel spacers between the wheels on the rear so the tires dont rub
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #9 of 19 Old 04-15-2013, 10:27 AM Thread Starter
PSDprepper's Avatar
I found a candidate truck, it is a 1990 dually cclb with a 5speed. its an idi. if I were to buy it could I swap the dually under, along with the zf5 and still keep my 4 wheel drive?
- Tyler
post #10 of 19 Old 04-15-2013, 11:47 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
if its a diesel you can swap in the trans, and if its 2 wheel drive you cant use the fronts, you will need either the spacers up front or actual dually hubs, and afaik dually hubs are only on 4x4 cab and chassis models, arrowcraft does sell a spacer for the front however
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
