Tensioner pulley - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-12-2013, 06:48 PM Thread Starter
Tensioner pulley
...keeps the serpentine belt tight.
Can the bearing be replaced, or is it one of those that is molded into the wheel?
Mine was squeaking a bit tonight, so I'm thinking I should replace it before it becomes an issue on the road!
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 8 Old 04-12-2013, 06:51 PM
JackedDaniels's Avatar
Pretty sure that its one piece you could probally jump on a auto parts store web site and check
Ford, First On Race Day!
EARLY '99 250
5" Flo-Pro, TS 6 Position, aFe Stage 2, more mods to come
Michigan Boys Do It Better!
JackedDaniels is offline
post #3 of 8 Old 04-12-2013, 10:21 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
Just replace the entire pulley. IIRC they are not very expensive at all. I am unsure if you are even able to get the bearing out. It would be too much work for the couple dollars saved if it is even possible.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 8 Old 04-12-2013, 10:30 PM
svranger25's Avatar
iirc correctly picked mine up for 15 bucks when mine decided to freeze on me
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #5 of 8 Old 04-13-2013, 12:28 PM Thread Starter
OK, Thanks!
Qwazert is offline
post #6 of 8 Old 04-13-2013, 06:33 PM
Quoted: 54 Post(s)
Don't even bother with the pulley. Replace the entire tensioner. The spring usually wears out long before the pulley bearing, so if the bearing is shot, the spring is probably up way past its bedtime.
madpogue is offline
post #7 of 8 Old 04-13-2013, 08:03 PM
OL' OutLaw's Avatar
fire it up and while it "Squeaking" drip a few drops of plain water on your belt....if it quiets it, it's the belt, not the pully....
they seem to last about 75,000 miles.....and NAPA has good quality replacements....
I have gently pried the seals out of the bearings, and re-greased them to get by for a while, but I do NOT recommend it....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #8 of 8 Old 04-14-2013, 11:55 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The bearing is $10 at napa and can easily be pressed out, the pulley with bearing is like $30, and can be easily changed, I replace when necessary but if I catch it before it goes I just replace the bearing
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
