Snap On mt2500and use with our trucks - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-12-2013, 05:06 PM Thread Starter
I am in the market for a good scanner and I found a snapon mt2500 for 200 with software up year 2001. Is this a good tool? can i perform buzz test with this guy? can you use it to measure your HPO health? any input would be great.
wstrnhauler4x4 is offline
post #2 of 8 Old 04-12-2013, 05:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
it will work as long as it has the ford cartridges
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 04-13-2013, 04:45 PM
Quoted: 83 Post(s)
Yes it is a very good scanner for use on the psd 7.3s and e4od trans. Make sure it has the ford odbII adapter and K19 (iirc) key. You can do buzz tests, contribution tests and see every that is being input to the ecm.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #4 of 8 Old 04-13-2013, 06:34 PM
Quoted: 53 Post(s)
Do some searching to confirm, but I think it requires the K2 or K2a key to communicate with the PSD.
madpogue is offline
post #5 of 8 Old 04-13-2013, 07:55 PM
OL' OutLaw's Avatar
yes, you will need the OBD II (B) adapter, and a K2-A key....same setup for an 2002 powerstroke.
I have one, and they are very good....
only problem is they eat 9-volt batteries..... keep a few Energizers around.
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #6 of 8 Old 04-13-2013, 08:09 PM
Quoted: 83 Post(s)
Yep, what Outlaw said, not sure why I was thinking K19
Jack
322000 miles
post #7 of 8 Old 04-13-2013, 08:27 PM
OL' OutLaw's Avatar
are you over 50 ?
post #8 of 8 Old 04-13-2013, 08:58 PM
I just thought my screen read "keep alive battery low,replace soon, located in left handgrip" as the default home screen
The Scanner works really good, I have had mine since 1995, and have kept it around for good reason. I would spend $200 on one if it had all the cartridges and OBD pins, lots of cars on the road that it still supports. Mine stays hooked up to the OBD a lot. There are a few things that it does not read on my truck for some reason...and my newer OTC will, but I do not get IVS, CLT or Engine RPM...but all the other data is there
Reed
1997 CCLB 4x4 ZF, 295-75-16 BFG A/T's, 16x8 ARE Outlaw II's, DP & 4" exhaust, 4" Skyjacker Suspension kit, FPR shim, DIY intake, Autometer boost and pyro, PHP Hydra Chip, DIY 140V IDM and E-Fuel are next!
Reed P is offline
