Oil Leak - Ford Powerstroke Diesel Forum
Old 02-08-2008, 07:59 AM
Oil Leak
I have a small oil leak that looks to be coming from under the Flywheel cover. What bad news is that? By the way it is an '03 7.3.
Old 02-08-2008, 08:06 AM
ADMIN AND TECH
it is possible to have hih pressure pump o-rings leaking , not very expensive , it is also possible for the intercooler and intake boots to just be seeping ,which is fairly normal and can be cleaned off from time to time , most 7.3 oil leaks are from the top end , will not be rear main seal or anything like that
Old 02-08-2008, 08:08 AM
But will you possibly notice the leak around that cover. It looks as if it is coming out of what looks like a weep hole. I will look further up to see if I see anything.
Old 02-08-2008, 08:31 AM
I went back and looked around up top and notice a puddle of oil under the fuel bowl in the valley. Could this be where the oil down below is coming from?
Old 02-08-2008, 09:00 AM
ADMIN AND TECH
yes sounds like high press. pump o-rings are leaking
Old 02-08-2008, 09:07 AM
what does it cost to have that fixed
Old 02-08-2008, 09:08 AM
I guess I will carry it to the shop tomorrow. Is this a high ticket bill or reasonable?
