Is it dead?! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-11-2013, 10:12 PM Thread Starter
HOYBOY's Avatar
Is it dead?!
So tonight I'm letting my truck cool down idle when I hear it.... s knock sounds like a sledge hammer against the block smoke from the valve covers and gritty oil on the dipstick so i don't know what happened running strong at 240000 and then this.....
SLOW STROKIN
2006 6.0 Amarillo
95 Ford F250 4x4 7.3 blue Charlene (sold)
94.5 Ford F250 4x4 7.3 Green two-tone Tracy (junked)
HOYBOY is offline
post #2 of 6 Old 04-11-2013, 10:19 PM
boozinag's Avatar
Threw a rod?
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 6 Old 04-12-2013, 12:48 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Sorry,...........
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 6 Old 04-12-2013, 01:50 PM
boozinag's Avatar
Check the turbo wheel, maybe the wheel chipped and a piece of metal when down the intake. I have seen pictures of fractured compressor wheels.
Gerry
184k
boozinag is offline
post #5 of 6 Old 04-12-2013, 01:54 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Wouldn't change the grit in the oil and knock sound. Hoyboy, what's your fuel pressure? You _might_ get lucky and the metal in the pan is from the fuel pump drive gear and the knock is from way too low fuel pressure. Or the HPOP threw up and is now not sending correct oil pressure/flow to fire the injectors well and again sending bits into the pan. Big "IF's" but worth a hope.
Matt
'97
-Stage II trans.
BigFuel is offline
post #6 of 6 Old 04-12-2013, 02:46 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
if there is metal in the oil then there is metal in all the bearings, the passages, and probably the injectors. diagnoses rebuild time
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
