Intro thread, Got my first truck and it had to be an OBS! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-11-2013, 01:47 PM Thread Starter
Hello everyone, The names Dean. Just picked up my first truck and "kinda" got what I wanted, almost a "so close, but so far situation" The truck is a late 94 350 2wd non turbo. I wanted a factory turbo truck, but all the ones I found were beat to ****. I paid 2500 for her and she runs like a champ but just doesn't have the power I want. I mod everything I get so I thought it would be a no brainer to just turbo the truck using factory psd stuff. It seems as tho I am mistaken and given the compression ratio it would be pointless to boost this motor.
Then the 2nd and 3rd problem. The truck is an xl which doesn't have any of the features Id like (chrome bumpers, cruise, power, cloth seats etc) so being that the body is mint and mint cclb psd trucks around here go for near 10k around here, should I find a wrecked truck and strip it? how hard would wiring the motor be seeing that turbocharging was an option? Also being a 2wd a d60 swap is on the list Im just getting conflicting info on if the frame is drilled for the mounts or not.Im open to suggestions, Thanks for your time.
1badgvr4 is offline
post #2 of 11 Old 04-11-2013, 01:55 PM
JBRIXEN's Avatar
nice find.
IIRC the front of the frames on the 2wd's are not boxed like the 4x's are.
the 7.3 PS is a completely different motor than the IDI. you are better off finding a turbo for your motor.
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #3 of 11 Old 04-11-2013, 03:13 PM
Full A-Team Member
Fordman247365's Avatar
Turbo and injector pump, IDI's will run too
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #4 of 11 Old 04-11-2013, 03:43 PM Thread Starter
I guess ill do more research on boosting the idi. Ford man could you take a pic of your interior I need to decide what seat combo to go with. Im too tall for the bench seats and all this sliding around is pissing me off.
1badgvr4 is offline
post #5 of 11 Old 04-11-2013, 04:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
look in the interior section, he has bronco buckets and 04-08 shift console
but if you find a wrecked psd your gonna need every single wire from it aside from headlights lol, you can turbo that motor, but not from a psd, totally different animal all together, nice looking rig tho, and as far as making it 4wd the frame is not boxed like a 4x4, and the cross member up front is not drilled for the trac bar mount, or up top to bolt in a d50, easiest option is use a dana 44 from an f-150/bronco and use heavy duty dana 44 hubs from an early 80's f-250, obs d60 wont be cheap or easy to find
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 11 Old 04-11-2013, 04:27 PM Thread Starter
Update I just passed a scsb psd at an abandoned house, Im gonna go by there tomorrow and see what the deal is. Couldn't tell if it was a 250 or 350 tho.
1badgvr4 is offline
post #7 of 11 Old 04-11-2013, 04:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
if its a short bed its a 250, they didn't have short bed 350's till 99
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 11 Old 04-11-2013, 04:41 PM Thread Starter
Ah well that sucks. If I can get it cheap I will, but Crew cab was something I had to have.
1badgvr4 is offline
post #9 of 11 Old 04-11-2013, 04:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
it will have the correct everything your going to need, aside from a solid front axel if it is in fact a 4x4, but while your doing your motor swap to a psd would be a perfect time to drill the holes your going to need or swap in a 3rd member for your 4x4
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 11 Old 04-11-2013, 05:00 PM
clatterindiesel's Avatar
Nice find.
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
