Help Direct Me In The Right Direction - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-10-2013, 02:28 PM Thread Starter
Not Far From Par's Avatar
Thought I would start a new thread rather than tag onto my one of my others...
Some of you might know.. I just bought my truck last week, & have done alot of basic maintenance on it to get it up to my standards..
My problem now is a decent sized oil leak..
At 1st I believed it to be the dip stick leak.. But was able to crawl under there today, & it is pretty clean & dry all the way around it.. But the symptoms pointed to that leak.. Oil all over the back of the pan & bell housing..
I am in no means looking for a perfect truck.. Especially with over 300k miles on it.. But this leak I'm sure will not let me have piece of mind between oil changes, & will very quickly have my wife yelling to park in the street!!
I did check the valley & all looks fine there.. Leak if definately on the passenger side of the truck.. So.. HPOP o'rings?
I will be cleaning up the bay a little this evening, & probably de-greasing this weekend to get a better idea.. But would appreciate being pointed in the right direction!!
2006 F350 CCSB
Toreador Red & Silver
Dove Leather
ALL STOCK (for now)
Not Far From Par is offline
post #2 of 18 Old 04-10-2013, 02:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The hpop is on the front, your gonna have to jump in there and trace it, check the turbo pedistol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 18 Old 04-10-2013, 03:39 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
And the 1" brass plug on the back of the passenger head.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 18 Old 04-10-2013, 03:55 PM Thread Starter
Thanks for the pointers guys...
I hope to have the found by this weekend..
2006 F350 CCSB
Dove Leather
ALL STOCK (for now)
post #5 of 18 Old 04-10-2013, 05:51 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
I would do what matt suggests with the plug in the back of the head. there are oil rail plugs in in each end of the head - i don't think they are brass - they seal with an o-ring eventually these o-rings fail.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 18 Old 04-10-2013, 05:56 PM
What he said..........
The EBP cylinder on the turbo pedestal is bad about leaking.
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #7 of 18 Old 04-10-2013, 06:37 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
They my not be brass. Just kinda thought it was zinc coated brass. Cheap stuff that looks strong
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 18 Old 04-10-2013, 06:48 PM
the baconator
Quoted: 141 Post(s)
i have 4 to replace mine. i will check
post #9 of 18 Old 04-12-2013, 08:45 AM Thread Starter
OK, so I had some time to root around in there yesterday..
Checking the valley... Dry as could be.. I actually had to vacuum some type of nest out of there.. looked like a birds nest, but was made of stuff I would normally associate with mice/rats.. Truck must have sat at some point.. Who knows.. But anyway.. DRY
From underneath, the dipstick tube "nut" the holds on the threaded "deal"(sorry.. blue collar here!!) Anyway, the nut was completely backed off & handing off the dipstick.. So I was thinking BINGO!!! Now we're cooking with peanut oil.. but no dice.. Looked to be dry as could be surrounding it as well..
But I do have an oil leak on that side.. it is coating my starter, & making a mess of about everything..
As far as the driver side goes.. Ran out of time to really tear into it like I did the passenger side.. As much as I am leaking.. I couldnt see the head being the source for either side..
Thoughts?
2006 F350 CCSB
Dove Leather
ALL STOCK (for now)
post #10 of 18 Old 04-12-2013, 10:40 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
HPOP rail plug. Fix that **** now or you'll be hurting something fierce later. When it finally goes it will dump all your oil in a minute. Look at the front of your heads for a large 1" plug. Looks like a big washer with a square drive or hex key to remove it. It's on the front and back of each head the head.
Matt
'97
-Stage II trans.
BigFuel is offline
