New truck.. Got a few q's - Ford Powerstroke Diesel Forum
post #1 of 48 Old 04-10-2013, 09:15 AM Thread Starter
460fordguy's Avatar
Hey guys I'm going to buy a 96 psd with the auto e4od. It has 295k on motor, 20k on tranny. Going to be project because it needs full exhaust plus downpipe. Interior will be striped because its red.(fugly). Want some tips on what I should look at. This'll be my first diesel so please help! Thanks
95 ford f350 rclb 4x4
-460
-e4od
-leveling kit
285 bfgs wrapped with moto metal 951
460fordguy is offline
post #2 of 48 Old 04-10-2013, 09:25 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check oil, check for blow by by flipping the oil fill cap, check turbo for dusting, check trans fluid for being burnt, get receipts on trans, and make sure to do a cold start, check for leaks, and fluid in the valley
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 48 Old 04-10-2013, 04:40 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
He pretty much covered it all!
Question- why flip the cap over? Cant you tell if theres blow by with the smoke that comes out the oil fill?
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #4 of 48 Old 04-10-2013, 05:02 PM
erics diesel's Avatar
There will almost always be smoke that comes out of it but with the cap flipped over the hole you can see if it has any pressure behind it
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #5 of 48 Old 04-10-2013, 05:33 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
OH gotcha, So im assuming pressure = bad?
tom
Other Rides
tkobes43 is offline
post #6 of 48 Old 04-10-2013, 05:38 PM
If it blows the cap off while running yes just make sure its not the engine vibration that moves it
post #7 of 48 Old 04-10-2013, 06:05 PM
Dirt rider1's Avatar
check turbo turbine fer play: pull off intake boot and grasp the turbine and try to wiggle it, if there is any play ur turbo is goin out.
Do not ferget the blowby check^^
Jordan
(dirt rider1)
1997 7.3 Powerstroke 2wd auto
Mods:
-Muffler cut off
-Cat. converter gutted and gone
-Diamond Eye 3" downpipe
-MBRP 4" exhaust (runs in front of rear wheel)
-Dodge Towing mirrors
-AFE high flow intake
-Real Tree seat covers
-Real Tree floor mats
-blacked-out headlights
-cab lights
-6 by 8' flatbed
-KC lights
-silencer ring removed
-17ton anchor shackle
Dirt rider1 is offline
post #8 of 48 Old 04-10-2013, 06:37 PM Thread Starter
460fordguy's Avatar
Thanks for the info. The steering column is out and has no exhaust/ downpipe or anything. So it's going to be impossible to hear it start. Just going to cross my fingers and hope he's telling the truth and I get a good deal. Anything I need to know about the hpop?
post #9 of 48 Old 04-10-2013, 06:47 PM
boozinag's Avatar
Is this gonna be a project or do you need it to be a daily driver? it might look good now, but once you get the juices flowing you may find leaks everywhere. How long has it been sitting unstarted and torn apart?
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #10 of 48 Old 04-10-2013, 08:10 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
seems like a compression check would be a good idea, and still check the turbo, inspect the fluids at least
why is the steering column out
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
