Power steering (pictures included) - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-09-2013, 04:57 PM Thread Starter
boozinag's Avatar
I noticed to today a leak coming from my truck while talking trucks with my buddy who has a 6.0.
The leak was on the passenger side and it seemed to be clear fluid, I am pretty sure it was Power steering fluid. I checked my power steering reservoir and it wasn't even registering on the dipstick. Also, the hose that goes into the reservoir has some play. I can push the metal end in to the flared part, and then pull it out about a quarter inch. I have included pictures of how much play there is. There seems to be fluid all over the area, and it is hard to pin point, so If the amount of play in that hose is too much, I am think that should be the culprit.
I also searched general, motor problems, and 7.3 tech files prior to starting this thread and found very little on power steering leak diagnosis.
First picture is with the hose fitting pushed in
The second is with it pulled out
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #2 of 13 Old 04-09-2013, 05:43 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I know with thoes types of fittings u should be able to spin the metal line whilte the fitting is tight as their is an o-ring inside that does the sealing. I dont think u whould be able to pull in and out on it tho. I think your o-ring is gone. Keep in mind if u ran the pump dry it may also be no good now also as they dont like being run dry.
I have a good supply line off my truck u can have for shipping if u want one. LMK!
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 13 Old 04-09-2013, 05:47 PM Thread Starter
boozinag's Avatar
I'd like to see if someone elses truck has similar in and out movement before I decide on changing it. I know a lot of people say to put ATF in the reservoir, but the fluid is clear/brown, so maybe my truck (only had it 10k miles) was last filled with PSF?
Gerry
184k
boozinag is offline
post #4 of 13 Old 04-09-2013, 06:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You parked next to a 6.0 and yours was leaking?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 13 Old 04-09-2013, 06:43 PM Thread Starter
boozinag's Avatar
I know, it was embarrassing! I am gonna buy the hose and replace it on thursday or friday.
Gerry
184k
boozinag is offline
post #6 of 13 Old 04-09-2013, 06:48 PM
mkeith54's Avatar
My PS hose blew right out as I was parking, the swedge or flare failed. Took about 30 minutes to change in the hotel parking lot.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #7 of 13 Old 04-09-2013, 07:22 PM Thread Starter
boozinag's Avatar
Good to know it was that quick. I will probably try to replace it tomorrow, provided the replacement part is in stock at my local parts store.
Gerry
184k
boozinag is offline
post #8 of 13 Old 04-10-2013, 05:26 AM
ol_Blue97's Avatar
u need a new hose.....and the pump specs out ATF. dont use power steering fluid when u re fill. i would also flush out the system with atf
FRANK THE TANK
post #9 of 13 Old 04-10-2013, 05:02 PM Thread Starter
boozinag's Avatar
Ok, thanks for the help fellas, and in particular from John (97beast). It actually wasn't the o-ring on the low side it was the white plastic o ring on the top fitting. The guy showed me a hydroboost and a normal hose in o'reilly's and I just grabbed the Non-hydroboost hose, only to figure out that it had the flared end, not the o-ring. Had to go back and get the right one. Had I bought the right hose it would have been a 10 minute swap.
Gerry
184k
boozinag is offline
post #10 of 13 Old 04-11-2013, 08:33 AM
dmr22's Avatar
Did that fix your leak? Mine is leaking and I am pretty sure it is leaking in the same spot.
FOR SALE
1995 Ford F-350 XLT
7.3~Extended Cab~Auto Transmission
dmr22 is offline
