Things To check....
Ok I got 176,000 miles on my car.
What are some maintenances to do on a 7.3l with that many miles? I have changed so far. Air Filter cleaning ( Has a K&N 2 of them) cleanined and oiled both Fuel Filter Also changed the CPS sensor ( It went bad) I wanna do an oil change but what oil and filter do I use and how much? I also wanna change the tranny fluid and filter if there is one so what fluid and filter do I get? can I do this myself? Someone told me to put 1 quart of transmission fluid into the gas tank before I fill it and that will help clean the injectors and engine etc... is this true? Also said to put a little bit in the oil? Ive never heard of this. Does this hold any value? -Thanks BTW I have the Automatic tranny the EAOD I think. car in sig. |
I use Motorcraft FL1995 filters and Rotella oil. You can use other brand oils, but only certain oils can be used in powerstrokes.
For Tranny fluid and filters, I would use Motorcraft also. You can do it yourself, but a good flush from a shop would be nice. Do not add tranny fluid to the oil and I would not use it in the fuel either. I have heard of it, but with all of the other proven and specifically engineered fuel additives around, You should use something else. I like Diesel Kleen, but many others ar as good, if not better. |
thanks man appreciate the info
I use ams oil and filters for everything, I dont know if I would flush an auto tranny with that many miles, I would just change it, but everybody has differing opinions on this. I do my tranny fluid every 25,000 and oil every 5,000 miles. As far as diesel additives, dieselclean works very well, and I have found the best is the crc diesel additive. good luck
Couple of things I forgot, I would also change the fluid in the front and rear diff's and the transfer case to.
If you can, use synthetic oil for the diff´s.
