Oil cooler rebuild - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-08-2013, 01:51 PM Thread Starter
superduty4x4's Avatar
Oil cooler rebuild
Set out to swap oil coolers on my pickup this weekend. My truck apparently has a 95 long block in it, which has the oil cooler header with the staked in bypass valve that is famous for falling out. I bought a used oil cooler from another member that came from a T444e and while the bolt patterns are the same, the way the cooler mounts to the block is different between the 2 enough that the 444e cooler won't bolt up to a PSD (or I didn't try hard enough to get the dang thing into place). So I pulled the one off my spare motor only to find a small crack in the rear housing:
It appears to be a sound repair but there was so much crud all over the outside of the oil cooler it was hard to tell if it's leaking or not. Long story short, can this oil cooler be used or should I just pony up and buy a new rear header from Riffraff?
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #2 of 3 Old 04-08-2013, 03:52 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Myself, I would probably get a new one. Check out Tousley Ford Parts online for their price on the header adapter (I see a price of $121.70, List price is $245.87):
Oil Filter Header (updated snap ring retained bypass and regulator valves)
(Ford) F81Z-6881-BA
Cheers!
Patrick Feeley is offline
post #3 of 3 Old 04-08-2013, 06:39 PM
OL' OutLaw's Avatar
get a new one....
Water in Pan = no bearings, no crank.... oil cooler cheap, engine spendy....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
