For anyone who needs acronyms for Ford - Ford Powerstroke Diesel Forum
Old 02-05-2008, 08:20 AM
Acronyms - Ford-Diesel Abbreviations, There are more but this is all I have.
2x4 =Two Wheel Drive
4r100 =Automatic Transmission 4 Super Duty Trucks with a 7.3
4x4 =Four Wheel Drive
ABS =Anti-Lock Braking System
AC =Air Conditioning
AIC =Auxiliary Idle Control
APCM =Auxiliary Power train Control Module
ATF =Automatic Transmission Fluid
BARO =Barometric Pressure Sensor
BB =Bulletin Board
BBS =Bulletin Board System
BCA =2nd Best Bearing Company
BTW =By the way
CC =Crew Cab (4 door)
CCV =Crank Case Vent
CDR =Crankcase Depression Regulator
CPS =Cam Positioning Sensor
DORA =Dealer Order Receipt Acknowledgment
DRW =Dual Rear Wheels
DTC =Diagnostic Trouble Code
DVOM =Digital Volt-Ohm Meter
E4OD =Auto Transmission on Pre-'99 Ford Pickups
EEC =Electronic Engine Control
EGT =Exhaust Gas Temperature
EOT =Engine Oil Temperature
FAQs =Frequently Asked Questions
FPR =Fuel Pressure Regulator
FWIW =For What it`s Worth
GM =General Motors
GP =Glow Plug
GPR =Glow Plug Relay
GVWR =Gross Vehicle Weight Rating
HEUI =Hydraulic Actuated Electronic Controlled Unit Injector
HPOP = High Presure Oil Pump
IAT =Intake Air Temperature Sensor
IDM =Injector Drive Module
LMAO =Laugh My Arse Off
IMHO =In My Humble Opinion
IMO =In My Opinion
LB =Long Bed
LOL =Laugh Out Loud
MAF =Mass Air Flow Sensor
MAP =Manifold Absolute Pressure Sensor
OBS =Old Body Style
OD =Over Drive
OEM =Original Equipment Manufacturer
OTC =Owatonna Tool and Equipment Company
OMG =Oh My Gosh*
PCM =Power train Control Module
PCV =Positive Crankcase Ventilation
PDL =Power Door Locks
PM =Power Mirrors
PS =Power Stroke
PSD =Power Stroke Diesel
PTO =Power Take Off (winch)
PTTTM =Power Telescoping Trailer Tow Mirrors
PW =Power Windows
PWM =Power Window Motor
RC =Regular Cab
ROFL =Rolling On The Floor Laughing
SB =Short Bed
SC =Super Cab (extended cab)
SRW =Single Rear Wheel
TC =Torque Converter or Transfer Case
TPS =Throttle Position Sensor
TSB =Technical Service Bulletin
TTM =Turbo Temp Monitor
VAC =Volts Alternating Current
VDC =Volts Direct Current
VECI =Volts Direct Current
W/E =What Ever
WOT =Wide Open Throttle
Old 02-05-2008, 08:35 AM
hey ya forgot some!!!!I will give ya one and you find the rest!!
hpop.......=______________
Old 02-05-2008, 06:21 PM
high pressure oil pump
Old 02-05-2008, 06:23 PM
International Threat
4R100 not 4L100....
CCV - Crank Case Vent
FWIW - For what it's worth
LMAO - Laughing my arse off
W/E - Whatever
IMO - In my opinion
ROFL - Rolling on the floor laughing
OMG - Oh my god
FPR - Fuel Pressure Regulator
OBS - Old Body Style
ok enough!
Old 02-05-2008, 06:56 PM
Thanks guys. If anyone wants to add to this list I will be more than glad to post them.
Old 02-05-2008, 07:10 PM
Rice Hunter
Originally Posted by Maintain View Post
4R100 not 4L100....
LMFAO- Laughing My Freak'n Arse Off
W/E - Whatever
IMO - In my opinion
OMG - Oh my god
ok enough!
Sorry Martin....had ta cut in brawdy
Old 10-05-2009, 12:07 PM
4R100 not 4L100....
ROFLMFAO- Rolling On the Floor Laughing My Freak'n Arse Off
W/E - Whatever
IMO - In my opinion
OMG - Oh my god
ok enough!
expanded one more!
IIRC - If I Recall Correctly
glad to finally this posted as a sticky, thanks!
Old 10-05-2009, 12:09 PM
What about FTW? I haven't the foggiest of ideas what that is.
Old 10-05-2009, 12:14 PM
FTW - For The Win - usually, it really depends on the context. if you google "acronym FTW" youll probably hit 10 or so definintions. but in our case i believe its For The Win mostly.
how about "PO - Previous Owner"
Old 10-05-2009, 12:16 PM
Thank you! How about "OP - Original Poster"
