Bad lope on startup - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-07-2013, 09:18 PM Thread Starter
atvfreestylekid's Avatar
Send a message via AIM to atvfreestylekid
Bad lope on startup
My dad just bought a 97 and it has a real bad lope on startup. I can bring the rpm's up to about 1k for a few seconds and then it idles fine. I unplugged the ipc sensor, checked valve cover gaskets, and has new filter. I don't know what else to do. Any help much appreciated.
2001 f-250 psd - 6 inch lift on 35's
1996 f-250 psd - 15 inch on 46's
atvfreestylekid is offline
post #2 of 12 Old 04-07-2013, 09:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That super cab obs is sick looking
But my 95 is doing the same, rocks hard until it warms up a little then runs fine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 04-07-2013, 09:43 PM Thread Starter
Thanks man. And this one lopes hard every time I start it. I can drive to town and back and kill it, but I can start it back up immediately after and it still lopes until I bring the rpm's up. I don't know. Getting frustrated.
post #4 of 12 Old 04-08-2013, 05:55 AM
I just started working on that problem myself
Mine even shut off on me a couple days ago. Started it back up with some throttle and everything was fine.
hithebrakes is offline
post #5 of 12 Old 04-08-2013, 06:22 PM
Try starting in neutral. If it's OK in neutral then it's the gear selector switch on the trans.
brooksbronco17 is offline
post #6 of 12 Old 04-09-2013, 05:34 AM
nice i will try that
post #7 of 12 Old 04-09-2013, 10:59 AM
Red '97's Avatar
check the uvch plugs that go under the valve covers to the injectors? mine had that symptom and that was one of the cases, they like to burn up if you didnt know already
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #8 of 12 Old 04-14-2013, 01:05 PM
Jerzyperson's Avatar
You check the CPS?
Jerzyperson is offline
post #9 of 12 Old 04-14-2013, 01:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
my cps is new, im thinking it could be the glowplugs not being hot enough
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 12 Old 04-14-2013, 02:20 PM
My had a lope. And I replaced CPS and it lightened. My injectors are the cause of my lope.
