I need help with batteries/Alternator - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-04-2008, 11:52 PM Thread Starter
scottphillips88's Avatar
Quoted: 4 Post(s)
Ok, so I just had two new batteries installed in my 97. (I wasn't about to mess around with my truck in -10 degree weather.) And on my way home from a 6 hour trip my battery light came on and my battery gauge was dipping to almost nothing. Before I knew it I had no lights or anit-lock brakes. I pulled over to check the battery connections. Sure enough my passenger side battery terminals were loose.
I tightened them up and jump started the truck. I then took it straight to my grandparents house thankfully 10 minutes away and charged the battery. Well, after it was charged I made it about 20 minutes before the same thing happened. This time I installed one new battery into the passenger side. This allowed me to continue for 2 hours towards home. I got home, but now my battery light is on again, and it's only a matter of time.
So, now the questions:
1. Should I start completely new and put in two new batteries that are for sure good? Would having my passenger side battery charged and my drivers side one dead give me the result I got. (few hours of driving but eventually dead.)
2. Or, should I expect that my Alternator is shot and replace it. Would Autozone be able to check my alternator without pulling it out and without two fully charged batteries?
3. Is there some other electrical problem that is messing up my truck?
Sorry this is so long, but there is no way to tell you smart guys everything in just a few words. All suggestions will be much appreciated
Thanks Guys!!! -Scott
scottphillips88 is offline
post #2 of 8 Old 02-05-2008, 12:05 AM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
I'm not one of them but it'll be a start for you anyway
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #3 of 8 Old 02-05-2008, 12:06 AM
95and05's Avatar
oops lost most of post but gimme a min and ill start over
94 IDI
95and05 is offline
post #4 of 8 Old 02-05-2008, 12:15 AM
95and05's Avatar
charge batteries up then do a load test on them both. disconnect the neg terminal from both. if you dont have a load tester Autozone should have one there. after batts are charged go to them while saving power ( turn off all unnecessary electronics lights radio ect) don't replace good parts do diag first.
Autozone should be able to test in truck ( mine does) but you can ck at home with a voltmeter (I will look for a link to post with these instructions if you are interested)
start by checking the alternator then if that is good look for other problems dont just throw $$$ at it till you do some basic diag. sorry for the goofed first post but I musta erased all this the first time.
94 IDI
95and05 is offline
post #5 of 8 Old 02-05-2008, 12:27 AM Thread Starter
Quoted: 4 Post(s)
Ok sweet. Thanks for the fast reply. First thing tomorrow I'm going to make sure I have two perfect batteries. This is a joke that I have to worry about this because I just bought two new ones. Maybe, i'll take them both in and use the warranty for two brand new one just to be sure
Once I know the batteries are both good and tightly secured I'll see if they stay charged, if not I think i can safely assume the alternator is out
post #6 of 8 Old 02-05-2008, 12:40 AM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
I say alternator is gone. if u didnt see ur batteries getting charged while u were driving.. its alternator
Class of Aug 17, CFD
lifewitlooie is offline
post #7 of 8 Old 02-05-2008, 12:06 PM
My 2 cents. My owners guide says you can charge one battery but if one dies you have to replace both. Don`t know why.
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #8 of 8 Old 02-05-2008, 03:58 PM Thread Starter
Quoted: 4 Post(s)
UPDATE:
I just put in two brand new batteries and checked all terminals. The truck starts but the battery light stays on. Also, the battery meter is on the N on normal. (Which is very low, however this is were it drops when the glow plugs are one....this time it just never pops back to normal.)
SO, I'm pretty sure my alternator is out unless someone can suggest something else like a relay that could cause the battery light to always be on and the gauge to read low with brand new batterie. Ideas?? Suggestions?? Thanks!
