New OBS/Project Log - Ford Powerstroke Diesel Forum
post #1 of 37 Old 04-07-2013, 06:45 PM Thread Starter
dmr22's Avatar
New OBS/Project Log
Finally was able to pick up my "new" truck on Wednesday. It is a 1995 F-350 dually. Currently has 260,000 miles on it, transmission was rebuilt 10,000 miles ago. Seems to be a good solid truck, definitely needs some TLC but appears to be a lot of truck for the money.
Here is what the truck looked like when I picked it up.
ID:	94105   Click image for larger version
FOR SALE
1995 Ford F-350 XLT
7.3~Extended Cab~Auto Transmission
dmr22 is offline
post #2 of 37 Old 04-07-2013, 06:48 PM Thread Starter
dmr22's Avatar
When I got home I noticed there was a significant oil leak. Saw it was looking from the oil pan. There is a nut on the passenger side of the oil pan that looks like it may have a sensor or something in it. I tightened the nut up and seems to be fine. Anyone know if I should take the nut off and put teflon on it or any other suggestions?
FOR SALE
1995 Ford F-350 XLT
dmr22 is offline
post #3 of 37 Old 04-07-2013, 06:52 PM
erics diesel's Avatar
that is your where your oil dip stick goes into the pan
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #4 of 37 Old 04-07-2013, 06:59 PM Thread Starter
dmr22's Avatar
I was able spend some time yesterday and today getting started on cleaning the truck up. I also changed the oil, removed the camper shell and side steps.
ID:	94153   Click image for larger version
FOR SALE
1995 Ford F-350 XLT
dmr22 is offline
post #5 of 37 Old 04-07-2013, 07:02 PM Thread Starter
dmr22's Avatar
That makes sense! I will just keep an eye on it. Thanks
FOR SALE
1995 Ford F-350 XLT
dmr22 is offline
post #6 of 37 Old 04-07-2013, 07:06 PM Thread Starter
dmr22's Avatar
Last post/question. I noticed this valve under the truck. It has a line the runs from the drivers side valve cover to the valve and then has another line that runs from the valve to a bung in the exhaust. Any ideas?
ID:	94169   Click image for larger version
FOR SALE
1995 Ford F-350 XLT
dmr22 is offline
post #7 of 37 Old 04-07-2013, 08:24 PM
sethc24's Avatar
Looks like the previous owner rerouted the crank case gases into a "catch" and then into the exhaust. As far as i know all you do there is drain the catch every oil change.
Some people just run a hose from the valve cover too atmosphere. Looks like you got a deluxe version lol.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #8 of 37 Old 04-07-2013, 09:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pretty nice rig there, I like the tail lights, and it no longer looks so grand pa with the topper missing
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 37 Old 04-08-2013, 05:14 AM Thread Starter
dmr22's Avatar
That's what I was thinking but wasn't sure. Could I just run it straight to the exhaust and get rid of the valve? The valve is pretty low to the ground and I'm afraid it's going to get ripped off.
Thanks! Yeah the topper and side steps definitely had to be the first things I took off.
FOR SALE
1995 Ford F-350 XLT
dmr22 is offline
post #10 of 37 Old 04-14-2013, 07:38 AM Thread Starter
dmr22's Avatar
Well I was able to get the seats out a couple of days ago to make cleaning the carpet easier. After looking at the carpet with the seats out I decided to just go ahead and pull the carpet out as well so I could clean it and try to get out the stains as well as give it plenty of time to dry. The interior of the truck is complete and in good shape but it looks like it hasn't been cleaned in about 6 years.
ID:	96738   Click image for larger version
FOR SALE
1995 Ford F-350 XLT
dmr22 is offline
