Fuel Filter .... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-07-2013, 08:04 AM Thread Starter
ChiefRocka's Avatar
Fuel Filter ....
So my dash light flickers and stays on from time to time....
Assuming it's time for a fuel filter.
I have the filter already.
Do I have to "reset" the light, or will it go out on its own ??
Also, what are the intervals, every other oil change, every oil change ??
Thanks ...
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 9 Old 04-07-2013, 10:49 AM
elrojo63's Avatar
It goes out on its own. Light is triggered when there's to much resistance. I usuaully change mine every 10k miles.
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
post #3 of 9 Old 04-07-2013, 06:31 PM Thread Starter
ChiefRocka's Avatar
That's what I figured ... every other oil change ?
John
post #4 of 9 Old 04-07-2013, 07:54 PM
bignate's Avatar
I go 5000 between oil changes and change the fuel and air filter every third.
Nate
1996 F250 4x4 7.3 5 Speed Ex Cab Short Box. Mods: 6637, 3"DP, 4" Exhaust, Beans 6pos Chip, Isspro 2 Pyro-Fuel-Boost, 255/85R16, 216,000 miles
Boost Fooler, 203deg Thermostat and Custom 12" sub center console on the way...
Wishing I was Fishing...
bignate is offline
post #5 of 9 Old 04-09-2013, 10:21 PM Thread Starter
ChiefRocka's Avatar
Ok, so I changed out the filter, and the light still glows....
Sensor ?
John
post #6 of 9 Old 04-09-2013, 10:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Have you cleaned any sediment from the bowl as well?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 9 Old 04-10-2013, 05:20 AM Thread Starter
ChiefRocka's Avatar
Uuuuhh, ya ... sure did, yeap....all clean !
The bowl did look clean, but I will pull it out again ... suck out the fuel, and make sure the second time !!
Thanks !
John
post #8 of 9 Old 04-12-2013, 12:54 AM
Quoted: 3 Post(s)
I understand the "fuel filter" light is connected to a vacuum sender on the side of the fuel bowl.
I have read somewhere that it is triggered at seven inches of mercury (vacuum).
If you have a vacuum gauge, you possibly could get a fitting to adapt it to where the sender is located and read the vacuum. If the vacuum is high and the fuel filter is clean, it could indicate an obstruction in the fuel line from the tank's pickup tube to the engine.
If the vacuum is normal (well below seven inches?), then perhaps the sender is faulty. By the way, normally the vacuum level is lower when at idle than when the engine is under load.
The sender is noted for leaking fuel on some trucks, which indicates it should be changed.
Airstreamer67 is offline
post #9 of 9 Old 04-12-2013, 08:33 AM Thread Starter
ChiefRocka's Avatar
I will definitely try this and report back
John
