'08+ differential cover gasket - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-05-2013, 10:14 AM Thread Starter
SoCalPwrStrk's Avatar
I am picking up the finned aluminum cover today, while searching the web i came across a gasket for this cover for $6.99, but everyone i see uses a permatex gasket maker. Is there an advantage to permatex over a gasket?
"Big Truck" 1997 F-350 CC DRW 4x2 Cali model
Diamond Eye 3" dp to 5" straight pipe, DIY 6637 intake, Pillar gauges, 6.0 trans cooler, Intercooled, TS 6 pos. chip with TW Tunes, 1.0 Housing, Barder Billet Wheel, EBPV Delete
"Baby Truck" 1999 Ranger EC 5 speed 3.slow
Camburg Long Travel, Billit upper arms, Fox dual rate coilovers and double bypass in front, Deaver race pack w/ fox double bypass in rear, fiberglass fenders, 16x8 American Racing Mohave Wheels
SoCalPwrStrk is offline
post #2 of 21 Old 04-05-2013, 10:29 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Other than that gasket supposedly being reuseable iirc, they do the same thing tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 21 Old 04-05-2013, 10:40 AM
jjones96's Avatar
I use right stuff gasket maker. Works awesome. U can make 15 or more diff cover gaskets with one can. Ur diff cover gasket u only get one. More bang for ur buck with gasket maker
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #4 of 21 Old 04-05-2013, 11:20 AM Thread Starter
What gear oil is everyone running? So many options, any suggestions?
post #5 of 21 Old 04-05-2013, 11:28 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
75w 140......
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 21 Old 04-05-2013, 11:38 AM Thread Starter
Any specific brand? blended or full synthetic?
post #7 of 21 Old 04-05-2013, 11:45 AM
Justin@DP-Tuner's Avatar
Quoted: 52 Post(s)
The Right Stuff works great.
No specific brand. Just 75w140 full synthetic.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 21 Old 04-05-2013, 11:58 AM Thread Starter
Sounds good, it may be kinda late to be asking this, but the 08 cover will fit on my dually right? i see a lot of dually on here with it, but everywhere i look it says will fit '86-'12 SRW
post #9 of 21 Old 04-05-2013, 12:31 PM
Quoted: 52 Post(s)
What is the part number of the one you bought? The dually axle takes a different cover I believe.
DP-Tuner
Like us on
Justin Bochmann
post #10 of 21 Old 04-05-2013, 12:40 PM Thread Starter
8C3Z-4033-A, got if off a write up from a guy who has a 97 short bed 4x4 dually, so he obviously did a dually conversion but that means he would have to have a dually axle, i read somewhere that the OBS duallies still had the stearling 10.25 it wasnt until '99 that they started using the Dana 80, this would be real easy if i had my truck right now. haha
