Body swap - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-04-2013, 04:03 PM Thread Starter
boozinag's Avatar
Body swap
It wouldn't be too difficult to swap an ECSB f150 body on to a SCLB F350 would it? The Idea would be to buy an ECSB f150, and an SCLB f350, swap the bodies and sell an SCLB F150 and keep an ECSB F350.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #2 of 12 Old 04-04-2013, 05:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Your going from single cab to super cab correct? Keep in mind the f150 must be late 94-96 to have correct holes in firewall and hole for PCM
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 04-04-2013, 05:26 PM
JSchuricht's Avatar
I don't think the wheelbase is quite the same but 99% of the body will swap over. The biggest thing you will need to swap is the radiator core support, other than that it's just going to be a bunch of little stuff like mounts and grommets for the accessories.
JSchuricht is offline
post #4 of 12 Old 04-04-2013, 05:58 PM Thread Starter
boozinag's Avatar
My brother has a 1995 f150 xlt with the 5.0 and 255k.
I was thinking of possibly buying it from him when he graduates, and having an F350 4x4 ECSB. I think it would be a neat little truck.
Gerry
184k
boozinag is offline
post #5 of 12 Old 04-04-2013, 06:29 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
different wheelbases and different frames the ecsb has a longer flat spot where the cab sits
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
post #6 of 12 Old 04-04-2013, 07:16 PM Thread Starter
boozinag's Avatar
I figured the major difference would be that the bodies were the same but the f150 frame would be less heavy duty than the 250/350 frames. So the body mounts are not at the same locations even though the frames are different?
Gerry
184k
boozinag is offline
post #7 of 12 Old 04-04-2013, 07:28 PM
the baconator
Quoted: 143 Post(s)
wy would the body mounts be in the same spot with different frames? and yes the 150 frame is different than the 250/350 frame
post #8 of 12 Old 04-04-2013, 07:46 PM Thread Starter
boozinag's Avatar
I guess my thinking was that all the bodies were the same, and had the same measurements and mounting sites, and the frames were built differently, yet still had the mounting locations for the bodies in the same locations since the bodies seem almost Identical. I haven't gotten a chance to check out the f150 compared to the F250 though.
Gerry
184k
boozinag is offline
post #9 of 12 Old 04-04-2013, 08:14 PM
JSchuricht's Avatar
The front body mounts should be in the same place, it's the rear mounts that would be in a different place due to the body being longer.
post #10 of 12 Old 04-09-2013, 09:27 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 117 Post(s)
The short bed will also have a smaller front tank.
There is a guy on here that has a CC with a micro box. I believe he relocated the rear cab mount crossmember and used a body lift to get the back of the cab to clear the frame kick-up.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
