Power Steering Pump Bracket Removal - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-04-2013, 01:22 PM Thread Starter
Is there a way to remove the power steering pump without removing the pulley first? I am replacing the pump and pulley, but messed up the lip on the pulley. I am unable to use the pulley removal tool because it just slips off. Can the bracket be removed? What needs to come off and where are the bolts? Thanks
1995 F350 Powerstroke Turbo Diesel 7.3l 2wd Crew Cab Automatic. 270,000+ miles
Bilstein Shocks, Aftermarket Downpipe, High Pressure Crossover Hose, Viper alarm and remote start, Tranny cooler, Cat delete, Homemade open air intake, Dick Cepek cab lights, Glow Plug Relay Mod, 140 IDM Mod, A/C Mod, SP Diesel Stage 1 Power Box, Hypermax Maxchip 300, Dual Electric Fans.
jtbel is offline
post #2 of 3 Old 04-04-2013, 04:30 PM
JSchuricht's Avatar
You can pull the whole bracket. You will need to unbolt the ac compressor and vacuum pump then there are 4 bolts holding the bracket to the block.
JSchuricht is offline
post #3 of 3 Old 04-04-2013, 05:02 PM Thread Starter
I already got the bracket off. Just 4 bolts and comes off with the vacuum and power steering pumps. Now I just need to figure out a way to get the pulley off the pump without using the standard pulley removal tool (because the center hole "lip" is ruined).
jtbel is offline
