tired of gauges - Ford Powerstroke Diesel Forum
post #1 of 23 Old 04-03-2013, 08:00 PM Thread Starter
StrokerIH's Avatar
Quoted: 7 Post(s)
tired of gauges
im tired of dealing with gauges going bad. does anyone know if there is a monitoring system that works well for our trucks?
97 F250 HD, XLT, ext. cab. long bed, 7.3 4X4, E40D, 3:55LS, 3" DP, 4" MBRP, 6" tip, No Cat, No Muffler, E-Fuel, TS 6 pos chip, Front add-a-leaf, 6637, Marinco mod, 265/75r16 a/t, Door keypad, Meyer 7.5' Poly Plow
03 Excursion 6.0, 4x4, 3:73, No Cat, No Muffler, Blue Spring, Coolant Filter, Zoodad mod, SCT X4, 24" wipers
StrokerIH is offline
post #2 of 23 Old 04-03-2013, 08:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Edge cs/cts, that new programmer/monitor/thing (infinity) from dp tuner, scan gauge
To name a couple
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 23 Old 04-03-2013, 10:17 PM
Justin@DP-Tuner's Avatar
Quoted: 66 Post(s)
Check out our Infinity. You will not find a more advanced setup available. Not only will it read every parameter the PCM sees, but you can also add additional inputs/sensors to monitor things the PCM will not see. This would include fuel pressure and EGT. It will also run 7.3L specific diagnostic tests, datalog, read/clear DTC's, etc.
HERE is a link to it.
Let me know if you have any questions.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 23 Old 04-03-2013, 10:22 PM
0317sprinter's Avatar
I know it's for the 7.3 but is it for all years 7.3??
0317sprinter is offline
post #5 of 23 Old 04-03-2013, 10:52 PM
Quoted: 66 Post(s)
If your 7.3L is OBDII compatible then it will work. Your 97 is OBDII compatible.
Even if you do not have an OBDII compatible truck(94 and some 95's), we can flash your PCM to be OBDII compatible.
DP-Tuner
Like us on
Justin Bochmann
post #6 of 23 Old 04-04-2013, 08:40 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Does the PCM have to be sent to you for obd2 compliance?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 23 Old 04-04-2013, 10:25 AM
Quoted: 66 Post(s)
Yes. If your PCM is not OBDII compliant, it would have to be sent in to us so we could flash it to a later code that is OBDII compliant.
DP-Tuner
Like us on
Justin Bochmann
post #8 of 23 Old 04-04-2013, 04:47 PM Thread Starter
StrokerIH's Avatar
Quoted: 7 Post(s)
anyone have any experience with aeroforce?
post #9 of 23 Old 04-04-2013, 05:22 PM
OL' OutLaw's Avatar
I'm just the opposite, I don't trust the electric crap......Isspro gauges pretty much work for Years.....but they're spendy
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #10 of 23 Old 05-01-2013, 01:37 PM Thread Starter
StrokerIH's Avatar
Quoted: 7 Post(s)
anyone got any other input?
