AA and AO Injectors in the Same Engine? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-03-2013, 07:01 PM Thread Starter
What I'm working on: 1994.5 7.3, 225k+, 5 spd, CCLB
I am slowly working my way through the various tests for Cranks/Won't Start and removed the valve covers today. So far the only question I can't find an answer to here on the forums is that my engine has both AA and AO injectors (3 AA, 5 AO). Is this normal or a problem? Also, all eight seem to have different part numbers on the top. Is this actually the part number or no?
Thanks in advance!
Haulstroker is offline
post #2 of 2 Old 04-03-2013, 09:02 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I believe those are serial numbers, and as far as aa and ao, I've heard the early ones had ao labeled on them as well being the same stick, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
