Sd axle to obs driveshaft options? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-03-2013, 05:25 PM Thread Starter
Put 03 superduty axles on my 97 ccsb. I've read for the front driveshaft best option is to change transfer case yoke so newer driveshaft can bolt on. My question is about rear driveshaft. I know I can get the conversion u joint, but I thought it might be beneficial to get the sd driveshaft on with the bigger u joints. Curious if sd driveshaft would hook right up to transfer case or if I would need a diff yoke to bolt on it?
Patlschr is offline
