What is a foil delete? and how is it done? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-01-2008, 11:22 AM Thread Starter
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
like the title says, I've heard of cat deletes, and muffler deletes. Not so much of a foil delete. When i was crawling around under my truck though i noticed that there is foil wraped around the downpipe.
I'm assuming that is what it means.
Someone explain this please and is there any bad things that could happen if i did it?
thanks )
Typical cummins owner.
taylorking is offline
post #2 of 2 Old 02-01-2008, 11:45 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
The foil delete pertains to '99.5 and up 7.3's. You just remove the insulation from the intercooler tubes. The foil on your down pipe should also be removed, along with the downpipe. The foil is a heat shield and I would leave it. An aftermarket downpipe is one of the first things that should be put on an OBS truck.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
