Tranny shifting .... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-03-2013, 06:15 AM Thread Starter
ChiefRocka's Avatar
You all are going to see alot of me here ... so please bare with me !!
The truck has a fresh built tranny with aprox 1000 miles on it (waiting on original owner to send me documents)
The truck has 315's on it (aprox 33") and I'm assuming stock gears ..
The tranny seams to shift fine while cruising and mild excelleration, but kinda "searches" when you play with throttle.
When I was a kid, (well, back in 95) my old boss purchased a '95 PS New.
He had me install a 'kit' on the tranny. Basically an inline box that consisited on un-pining the harness plug, and running wires into the box and then others into tranny.
It made a big differnce in getting rid of the 'cadillac' shifts.
Any thoughts on improving shifts ?
Smooth shifts = increased temps ..... not good
Hypermax offers valve body uprgrades too ...
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 5 Old 04-03-2013, 07:12 AM
Full A-Team Member
Fordman247365's Avatar
Put in either a BTS or John Wood valve body
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #3 of 5 Old 04-03-2013, 07:23 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
The kit was a shift controller from the likes of Banks Power. It firms up the shifts and slows the commands from the PCM to make smooth yet powerful shifts. This is older technology that where it is still available installing a V-Body, like Shane said, will serve your Trans a lot better. Also, today's tuners are able to build those older shift controllers right into their tunes when you buy a chip for your truck.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 5 Old 04-04-2013, 05:48 AM Thread Starter
ChiefRocka's Avatar
That's what I figured ....
But thought I would just share some of my past !
John
post #5 of 5 Old 04-04-2013, 08:44 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Agreed, and what is stock gearing?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
