No start with chip installed - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-02-2013, 03:48 PM Thread Starter
I had an issue with a no start/random stall when I had my chip installed. I removed the chip, and the problem went away. Reinstalling the chip gives a no start. I have removed the PCM and cleaned the contacts, but even now reinstalling the chip causes a no start. The check engine light comes on when you turn the key to run, the WTS light comes on, and the truck won't start. Any suggestions?
sgg93 is offline
post #2 of 11 Old 04-02-2013, 04:10 PM
jjones96's Avatar
Keep cleaning on the contacts where the chip plugs in use some alcohol it helps.
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #3 of 11 Old 04-02-2013, 04:43 PM Thread Starter
I hate to take any more off of those contacts. I cleaned them with paint thinner and a scotchbrite pad, as well as electronics cleaner. I also scraped them down a little bit with a razor blade, and I believe I got all the lacquer off.
sgg93 is offline
post #4 of 11 Old 04-03-2013, 05:55 AM
superduty4x4's Avatar
Bad idea...
sgg93 sounds like there is an issue with the chip itself. You'll need to send it off for a re-burn.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #5 of 11 Old 04-03-2013, 06:19 AM Thread Starter
Alright. I've been trying to get in touch with Tony, who wrote my tunes, but that in and of itself can be quite a feat. I may just box it up and send it back to him. Hopefully a re-burn solves my issues.
sgg93 is offline
post #6 of 11 Old 04-03-2013, 06:34 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
are you sure you didn't take to much off? if it starts without chip then you know its the chip...also try to start it on diffrent tunes to see if just one file is bad...Hope you get er dun, you'll be happy once you get it done
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #7 of 11 Old 04-03-2013, 07:34 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Cary burns and honors Tony's free reburns. He's easier to get a hold of and shipping is quicker. Use the search above and type in CT Performance.
[EDIT] I see that you are in Texas. Never mind my other post. Maybe just drive over to Tony's shop?
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 11 Old 04-03-2013, 08:11 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Hard for me to talk on the phone with Morgan's situation, have you sent me an email?
Where you located at?
Just looked at a few of your previous posts regarding your starting/running issues with the cel's and such.
Just so you know, if you have a problem with the charging system, the chip will not function correctly, and you stand a decent chance of eventually toasting the chip with some of the issues your listing. I would highly recommend you remove the chip until you find out what is going on with the charging system.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #9 of 11 Old 04-03-2013, 08:35 AM Thread Starter
I totally understand the situation with Morgan, and I very much respect the fact that you're staying in the business and balancing family issues at the same time. I did send an e-mail about a month ago, but it's possible it got lost in the system. My charging issues were back in January, and the chip was functioning great until about March. I'm presently in NC (need to change that profile of mine) going to college, but I will be in Texas in July. The thing that got me was the intermittent stalling before I got a stubborn no-start. I really do like running the truck with tunes, and I need to find out what it's going to take to get it up and running with tunes.
Tony, would it be alright to box it up and ship it to you?
Regards,
Cole
sgg93 is offline
post #10 of 11 Old 04-03-2013, 09:04 AM
twildman's Avatar
Quoted: 2 Post(s)
Regards,
Cole
You bet send it on!
twildman is offline
