Solid axle swap - Ford Powerstroke Diesel Forum
Old 01-31-2008, 10:01 AM
Question Solid axle swap
Has anyone done this on their f250? I am looking into it for my 1997 f250. Just wondering if anyone has any prior experience with it and they want to make a suggestion or a warning. any help welcomed
Old 01-31-2008, 10:04 AM
Uh.....if it's 4wd, doesn't it already have a solid front axle???
Old 01-31-2008, 10:09 AM
a truck
no the 94-97 f250s have a ttb (twin traction beam) front suspension and they are a real pain to lift took me two weeks to lift the front which is why Im probably going to do a solid front axle swap in the future too.
Old 01-31-2008, 10:15 AM
Well there you go. Learn something new everyday.
a truck
Yeah I have it on my 86 F150 too I really dont like it that was fords mistake suspension I think
Old 01-31-2008, 10:50 AM
search button can be your friend...
dana 60 swap
front axle swap
Old 01-31-2008, 02:20 PM
BIG TRUCK, SMALL DRIVER
TTB's are good for stock trucks. If you lift, I like the solid better. I did the swap on a '88 f-250. I had a complete dana 60 from caliper to caliper. It swapped right in, no problems, other than finding u-bolts. Make sure the left side mounting plate that the u-bolts go through comes with your axle. You may have to add blocks or add a leaf to the rear to level the ride. Depends on the truck and amount of spring droop. I didn't have to add anything, but I had a 6" lift already installed.
Old 01-31-2008, 02:24 PM
OUCH! took me and a buddy a day and a half and 2 cases of beer. I would still have to agree that it is a PAIN IN THE AZZ to lift!!!!!!!!
Old 01-31-2008, 02:31 PM
a truck
yeah I made the mistake of doing it by myself so that was probably a bad idea
Old 01-31-2008, 05:50 PM
I think its "easier" if you have an F350 sittin next to it...its almost a direct swap I believe. Think '80-'97 front axle will work. Was thinkin about doin it to my dads 88 250; was gonna buy it from him and lift it but wanted a diesel BAD!!
