4x4 hubs - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-01-2013, 03:52 PM Thread Starter
4x4 hubs
I have a 95 f350 and today I went to put my truck in 4hi today and my front hubs never locked in. I have access to a parts truck that has warn premium lock outs that I can get for free. Now since I'm pulling everything off an existing truck with the lockouts do I still have to buy a nut kit for the auto to manual conversion? Correct me If I'm wrong I don't fully know how the auto hubs work either but don't they activate by vaccum of is that just the superdutys? If so where are the vaccum lines so I could check those to make sure those still are good until I can swap manuals in. Thanks for looking hope you guys can post me in the right dorection
Sent from AutoGuide.com App
strokinandsmokin95 is offline
post #2 of 7 Old 04-01-2013, 04:06 PM
erics diesel's Avatar
I switched mine from the factory ones to warns with no extra kit
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 7 Old 04-01-2013, 05:12 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i would take the manual nuts, however the lock out hubs seem to work with the auto nuts. and no vacum lines on an OBS
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 7 Old 04-01-2013, 06:22 PM Thread Starter
How do the front hubs lock in then if they're automatic?
post #5 of 7 Old 04-01-2013, 06:28 PM
the baconator
Quoted: 143 Post(s)
soehow when you shift the t case into 4x4 either high or low and then move forward/backwards they lock/unlock. when you engage 4x4 with the t case the axle shaft spin inside the hub and lock the hubs, how exactly i don't understand
post #6 of 7 Old 04-01-2013, 06:33 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
When you lock the t-case in and the front axles start to turn, then hubs lock when they start to rotate. I had a 95 that originally came with auto hubs. The original owner swapped to manuals without the nut kit. Needless to say, I replaced the hubs because the nut and lock ring came loose and destroyed the inside.
dhanna6powerstroke is offline
post #7 of 7 Old 04-01-2013, 08:56 PM
boozinag's Avatar
I have had good luck with my autos, but if you can get a solid set of Warn hubs for free I would jump on it. I don't think any kit is necessary as I have seen several Dana 60 rebuild write ups where people have gone from autos to lockers and vice verse.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
