Driveshaft lengths - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-01-2013, 07:45 AM Thread Starter
clatterindiesel's Avatar
Driveshaft lengths
Quick question guys. Im thinking it is uniform and the same. But before i pass on jncorrect info.
Are the front driveshaft lengths the same for a ecsb and cclb truck. Both 96 year models. Thanks
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
post #2 of 10 Old 04-01-2013, 08:00 AM
Sam Burton's Avatar
as long as they had the same transmission they should be the same length.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 10 Old 04-01-2013, 08:23 AM Thread Starter
Kudos for quick reply. Found a gasser 460 with auto cclb. Gonna swap everything from the ecsb psd with zf5. Thanks. So we will be looking for a new driveshaft
post #4 of 10 Old 04-01-2013, 08:28 AM Thread Starter
It doesnt matter if going from a ttb to d60?
post #5 of 10 Old 04-01-2013, 08:29 AM Thread Starter
Actually we wont need a new one DS if we swapping motor and tranny and tcase. So thats good. Just concerned with any length differences in the straight axle one and independent one
post #6 of 10 Old 04-01-2013, 05:02 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i know you have your issues solved, but just FYI: the TTB in the ECSB (and all 250s) have a different drive shaft than the CCLB (and all 350s) the 350 uses a double cardan joint and the yoke off the T-case is different for the 2 driveshafts
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 10 Old 04-01-2013, 05:46 PM Thread Starter
Thank you terry. We were looking under my F350s and his F250 and noticed the difference.
post #8 of 10 Old 04-01-2013, 05:48 PM Thread Starter
We would just have to change yoke on transfer case right? And then find appropriate drive shaft from a F350 that is correct length. Basically out of a manual 4x4 diesel F350. I am correct in that assumption right?
post #9 of 10 Old 04-01-2013, 05:55 PM
the baconator
Quoted: 146 Post(s)
yes and i don't know if an auto one will work the difference in length can't be much if any
post #10 of 10 Old 04-01-2013, 06:41 PM Thread Starter
Yeah. The transmission lengths i think will mess up the driveshaft lengths.
