No Heat - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-01-2013, 07:27 AM Thread Starter
No Heat
I have a 94 powerstroke and I cannot get heat into my cab, i put a new thermosate in it and the lines going to my heater core get hot but i barley get any heat i cannot figure this one out...
94powerstroke12 is offline
post #2 of 5 Old 04-01-2013, 07:30 AM
Full A-Team Member
Fordman247365's Avatar
The line coming out of the heater core hot also?
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #3 of 5 Old 04-01-2013, 07:31 AM
JBRIXEN's Avatar
are both lines to the heater core hot?
sounds like the air flow through the heater core or evap core it plugged.
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #4 of 5 Old 04-01-2013, 07:39 AM Thread Starter
Both lines are hot so maybe the air flow through the core?
post #5 of 5 Old 04-01-2013, 07:41 AM
JBRIXEN's Avatar
check that the blend door is working properly, but those are the two most common problems.
JBRIXEN is offline
