obs rear door locks don't work. Need help. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-31-2013, 03:04 PM Thread Starter
strokin95style's Avatar
My 1997 crew cab rear doors will not lock or unlock with the switch. I took the door panels off and noticed that both rods coming out of the actuator were unhooked from the lock mechanism. Both front door locks work fine. Where do I need to start looking into this? It's not real important but I would like to get it fixed so I can get my keyless entry fixed. Thanks guys.
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #2 of 7 Old 04-01-2013, 08:32 AM
Full A-Team Member
Fordman247365's Avatar
You hooked the rods back up and the locks still dont work?
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #3 of 7 Old 04-01-2013, 02:54 PM Thread Starter
Correct. They were unhooked and they don't even move with the lock buttons. How can I test the actuators without removing them? Or should I be looking somewhere else?
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
post #4 of 7 Old 04-01-2013, 07:30 PM
Full A-Team Member
Check the wiring where it comes into the door, it is a known breaking spot for wires
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #5 of 7 Old 04-01-2013, 08:03 PM Thread Starter
Thanks. Would you happen to know which color wire it is to the actuator?
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
post #6 of 7 Old 04-01-2013, 08:09 PM
Full A-Team Member
That I dont know, but for whatever reason that part of the wiring isnt good, I have problems with my rear windows all the time...and it is broken wires every time. Worth a quick look in there
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #7 of 7 Old 04-01-2013, 08:41 PM Thread Starter
I'll check into it my next day off.
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
