screetching noise from trans - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-31-2013, 08:27 AM Thread Starter
Well hello all lets see if I can explain this to yall, Let me break it down. If i have the clutch out and in neutral and i press the clutch and try and go into second i get a screetching noise like a bearing, I first thought it was a pilot bearing but it only does it in second gear all other gears are fine. Im going to drain and refill the trans because the oil is dark, it is full, any idea of whats going out? is it a bearing or a syncro? Thanks all
Turbo_pace is offline
