Sick to my stomach - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-29-2013, 11:33 AM Thread Starter
PSDTV21's Avatar
Sick to my stomach
Currently in the process of changing the head gaskets on my 94. Have one side done already and was working on the other side. Got the head off and was looking down into the block and notice some gunk in there. So went ahead and starting cleaning it out. While finishing up I was looking at the block and noticed a wet spot. Wiped it dry and went back to flushing it out. Looked again and noticed it was wet again. Grabbed some brake cleaner to find thisSick to my stomach-imageuploadedbyautoguide1364585488.051668.jpg
226000 miles. Never really heard of this on a 7.3 so thought I would share.
Sent from AutoGuide.com App
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #2 of 14 Old 03-29-2013, 11:45 AM
97powerstroker's Avatar
Quoted: 8 Post(s)
Wow did you ever see a leak prior to this? first time i have seen it.time to upgrade i suppose
2002 F-250 7.3 auto CC/SB lariet 115k miles and 100% stock!
1996 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #3 of 14 Old 03-29-2013, 11:50 AM
Quoted: 3 Post(s)
yikes.. .
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #4 of 14 Old 03-29-2013, 12:22 PM
OL' OutLaw's Avatar
that's exactly what happens to ANY engine that is run without changing the coolant once inna while...
people will have a small leak, and just keep adding water....next winter...
* CRA C C K K K *
if you NEED to run it a while, you can find a couple bottles of "Bar's Leaks" .. it is absolutely the best stop leak made....get some, follow the instructions to the letter, and it will seal it up.... and don't bother trying anything else....
and you will HAVE to run straight water..... you can even do this in the winter, you just MUST keep it plugged in.....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #5 of 14 Old 03-29-2013, 01:00 PM Thread Starter
PSDTV21's Avatar
It did leak but I thought it was because of the bad gasket. The engine is on a stand right now so I definitely wont be driving it
-Tyler
1994.5
PSDTV21 is offline
post #6 of 14 Old 03-29-2013, 09:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That's terrible, but a good block only could be found, guy selling one on here in the classifieds, suks when it happens tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 14 Old 03-29-2013, 09:32 PM
Could that be repaired by someone who knows how to weld cast iron?
99' Powerstroke is offline
post #8 of 14 Old 03-29-2013, 10:03 PM
boynamedsue's Avatar
I know a guy who has been doing it for years with success. He did mine on my jeep once, worked fine but it really does matter where the crack is in that block.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
boynamedsue is offline
post #9 of 14 Old 03-30-2013, 12:46 AM
Rodslinger's B1TCH
the cummins 53 blocks from '98-'01 are well known to develop 6-7" cracks in the water jacket. there is actually a special welding rod out there designed to fix engine block cracks.
if your engine is out of the truck it shouldn't cost much to have a welder fix it up for you. to do it properly does take time though. it needs to be heated and cooled properly a few times in the process.
steve604 is offline
post #10 of 14 Old 03-30-2013, 04:33 AM Thread Starter
PSDTV21's Avatar
I knew that 24 valves with the 53 block would do that. Actually one of my buddies has one with 280000 on it with mods. As for fixing this, Im shied away from having it stitched or welded. I haven't heard a lot about stitching. Its about six inches long on the passenger side starting at a freeze plug heading toward the drain plug. I think Im going to try and find a block and swap everything over.
-Tyler
1994.5
PSDTV21 is offline
