Boost and map line - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-28-2013, 07:26 PM Thread Starter
Phillipjon's Avatar
Quoted: 77 Post(s)
Boost and map line
I am in the middle of installing a 7.3 Intercooler on my 1996 F350 CCLB. My question is where is the best place to put the boost and map line, hot side or cold side, in the pipes or the e99 spyder and the pros and cons of both?
Thanks,
Phil
Phillipjon is offline
post #2 of 19 Old 03-28-2013, 07:29 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Install it in the hot side pipe, the spyder would be more ideal tho, the sooner it reads boost the faster it sends fuel
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 19 Old 03-28-2013, 07:30 PM
Quoted: 82 Post(s)
Map line to the hot side of the spider with boost line tee'd into the map line. Pro is less turbo lag, con don't know of any.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #4 of 19 Old 03-28-2013, 07:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Con is you gotta drill lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 19 Old 03-28-2013, 07:34 PM
Quoted: 82 Post(s)
I suppose that is true. Phil did you get the correct turbo to spyder clamp?
Jack
322000 miles
post #6 of 19 Old 03-28-2013, 07:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
He does, like 20 minutes from me gave him the part number
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 19 Old 03-28-2013, 07:52 PM Thread Starter
Phillipjon's Avatar
Quoted: 77 Post(s)
Will the gauge flutter if I tee into the map line or is it best to tap the spyder twice? Yes I have the right clamp ther is even a oring type of seal that goes between the turbo and spyder.
post #8 of 19 Old 03-28-2013, 08:10 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Supposedly it does not flutter as much, but no experience as of yet, auto meter has a suppressor for their gauges for that
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 19 Old 03-29-2013, 07:31 AM
Full A-Team Member
Fordman247365's Avatar
There is zero flutter with it in the map line in the hot side close to turbo.
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #10 of 19 Old 03-30-2013, 07:38 PM Thread Starter
Phillipjon's Avatar
Quoted: 77 Post(s)
What if I put a (T) in and put in the hot and still leave it where the factory put it?
