Suggestions- buy or not? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-27-2008, 05:20 PM Thread Starter
superduty4x4's Avatar
The truck I'm looking at is a 97 F350 crew cab 4x4, E4OD, 110K miles, spray in liner, aluminum wheels, 2 new batteries, new starter, new alternator, chipped, Banks Transcommand, newer tires, pillar pod with boost/trans temp/EGT, new exhaust with down pipe, full loaded XLT. The bad news is, it was hit in the front and the frame is bent bad enough to need to be replaced. The guy is asking $6K for it. From looking at the photos, I don't think there's any way the frame can be fixed, so I'm looking at having to strip the truck all the way down and throw a new frame under it. I don't have a problem doing the work, I'm just wondering what kind of time might be involved- I'm thinking probably a month worth of weekend work should get it back up and running again. Thoughts?
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #2 of 14 Old 01-27-2008, 05:25 PM
Price sound a little high to me if the frame is that bad.....
forddieseltweek is offline
post #3 of 14 Old 01-27-2008, 05:26 PM
sldghamr's Avatar
did a salvage title get put on it?? if not, i would say, buy and replace the frame.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #4 of 14 Old 01-27-2008, 07:11 PM Thread Starter
Salvage title. All the body work (save the bumper) is still straight, the part of the frame that is bend are the tubes that extend forward of the core support mounts, they are pushed 3-4" to the passenger side:
post #5 of 14 Old 01-27-2008, 07:18 PM
The Fat Mod
Logan's Avatar
I say it is a little high. You would also need to see if you can find a new frame first.
Logan is offline
post #6 of 14 Old 01-27-2008, 07:19 PM
The Fat Mod
Logan's Avatar
Course, I am not sure if this can be done, but I am sure it can. If the rest of the frame is good, then cut out the bad, and weld in new frame with the right supports.
Logan is offline
post #7 of 14 Old 01-27-2008, 07:36 PM
Rice Hunter
Diesel Freak's Avatar
A bit high I think!! You may find a good frame man locally that may stretch it back out and track perfectly. I did this some years back and saved a ton! Good Luck!!
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #8 of 14 Old 01-27-2008, 08:45 PM Thread Starter
Would $4500 be more in line? I didn't figure there was a snowball's chance in you-know-where the frame could be straightened back out. I've found a few frames by looking on car-parts.com, the most expensive were $1000 but many were less. Cutting/welding might work but that's not something I'd like to tackle... I wouldn't feel good throwing my family in the truck not knowing what might happen if we were to get in an accident.
post #9 of 14 Old 01-28-2008, 05:45 PM Thread Starter
Here are some more photos:
post #10 of 14 Old 01-29-2008, 01:49 PM
Have you looked at it yourself? Is it really JUST the frame that is bent? You may want to look close at all the suspensions mounts, etc. to make sure there isn't any breakage there.
Zique316 is offline
