Brake problem. Assuming booster - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-27-2013, 09:33 AM Thread Starter
My 96 4wd is having a weird problem. I know the booster is the culprite for a lot of problems with the pedal leaking down but with mine it's a hard pedal.
When I stop i have no problems but if I'm at a stop sign and making my way up from a few cars being or pulling into a parking space I get one good stop then I have a hard brake pedal and I have to really stand on it to stop. I get no pedal leak down either. Another symptom is if I stop at a light after a few seconds my brake light comes on the goes off when I start driving.
Thanks for the suggestions.
Impulse138 is offline
post #2 of 9 Old 03-27-2013, 10:35 AM
superduty4x4's Avatar
Vacuum pump is waving bye-bye.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 9 Old 03-27-2013, 10:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Same thing happened to me twice in 2 trucks, it's the vacuum pump
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 9 Old 03-27-2013, 10:45 AM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
X3! Cheers!
Patrick Feeley is offline
post #5 of 9 Old 03-27-2013, 11:21 AM Thread Starter
Thanks everyone.
Where can I get a quality one for a decent price. In read that the cardone or whatever they are called are junk.
post #6 of 9 Old 03-27-2013, 11:25 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I got mine at o'reilly auto for $100 iirc, then had them warranty it for the second one, has a lifetime warranty
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 9 Old 03-27-2013, 11:51 AM
i would check for a leak before buying a new pump
taylorkoch23 is offline
post #8 of 9 Old 04-09-2013, 07:31 AM
StrokinNSmokin6.0's Avatar
Did you find your problem? I am having the same issue but I have a brand new vacuum pump, however mine seems to be intermittent.
04 F350 With all the mods.
StrokinNSmokin6.0 is offline
post #9 of 9 Old 04-09-2013, 01:30 PM
PowerstrokinIt F250's Avatar
if its not the pump try adjusting your brake shoes, as they set the height for your pedal. i couldnt figure out why my brakes wouldnt right after i had replaced shoes and drums the last time.
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
