7.3 interchange - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-26-2013, 07:02 PM Thread Starter
7.3 interchange
Hi, new to the forum, I have a 97 F350 Powerstroke and was wondering if I did a engine swap with a pre 97 7.3 if I would run into any issues. thanks in advance
My97Powerstroke is offline
post #2 of 4 Old 03-26-2013, 07:03 PM
JD3020's Avatar
94.5-95 have different timing covers and HPOP's, but thats about. And those can be swapped easily.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #3 of 4 Old 03-26-2013, 08:17 PM Thread Starter
Thanks for the information. I have a line on a 95 and a 96 engine.
post #4 of 4 Old 03-26-2013, 09:23 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Make sure yours is not a California model, they have ab code split shots, slightly larger and different pcm's and wiring, if not then yes they are all fine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
