Spooling?? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-26-2013, 01:32 PM Thread Starter
Quoted: 4 Post(s)
Question Spooling??
I've heard the term spooling a lot and just wondering what that is or means? I'm thinking maybe it's when the turbo kicks in when cruzing down the interstate and makes all that loud noise like my "95" 7.3 does. It also sounds the same way in the morning when just started and I go a few miles, then the noise stops. Also wondering what's a boost gauge good for? Thanks ahead of time for answering my questions.
timlsalem is offline
post #2 of 7 Old 03-26-2013, 02:02 PM
boozinag's Avatar
spooling is when your turbo is gaining momentum when you are at low speed and accelerating.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 7 Old 03-26-2013, 02:18 PM
stroken96's Avatar
a boost gauge tells you the psi of air the turbo is pushing into the engine
stroken96 is offline
post #4 of 7 Old 03-26-2013, 03:07 PM
JD3020's Avatar
That noise you hear is probably the fan engaging, or possibly the back pressure valve closing.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #5 of 7 Old 03-26-2013, 03:25 PM
stroken96's Avatar
what year 7.3 are you parting out
post #6 of 7 Old 03-26-2013, 06:55 PM
JD3020's Avatar
Updated my sig, but its a 97 engine.
Jimmy
JD3020 is offline
post #7 of 7 Old 03-28-2013, 03:41 PM
stroken96's Avatar
oh ok thought maybe it would be 99.5-03
