help me find the leak - Ford Powerstroke Diesel Forum
Old 01-25-2008, 04:14 PM
i have developed an oil leak. it is under the driver side exhaust manifold of my 1996 obs the lines come to the front and make a loop on the frame, also above the lines is there a oil cooler? i looked up there and seen a round object about a foot long ending at the oil filter, i can not see if the lines are leaking or if it is a oil cooler leaking if i have one. the truck has 259k and has never had a leak before and would like to fix it myself and not take it to the dealer any help would be great and thanks in advance
Old 01-25-2008, 04:16 PM
yes you do have an oil cooler and it is not uncommon for the o rings at the ends of the cooler to leak. not to hard to do just very messy!
Old 01-25-2008, 04:27 PM
Yea I have the same problem with my truck same year. I was told to looking in the valley for a puddle of oil. So you should go check yourss!!
Old 01-25-2008, 04:33 PM
