Replacing Water Pump- What other stuff should I look to replace? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-26-2013, 07:47 AM Thread Starter
I am replacing the water pump this weekend and was curious what else I should change while in there.
So far, I have picked up:
Water Pump w/ Lifetime Warranty
Thermostat
I would like to replace all hoses and other parts while in there, including swapping over to different coolant and adding a coolant filter. However, I am in a rural area and need some part numbers so I can order everything in. We do have a NAPA, but that is it. Many times, they have to order it in as well.
Any part numbers or recommendations would be greatly appreciated. Thanks.
96 F250 CC SB auto 104K miles, intercooled, SORD RSK, d60 swap, electric fuel conversion, 4.5" lift, chipped, gauges, 6637 filter...
PhillyB is offline
post #2 of 6 Old 03-26-2013, 09:24 AM
joedown's Avatar
See this thread.
International waterpump
96 F350 4x4 XLT 7.3 59,428 orig miles, Stage I's, Adrenaline, IDM, gutted EBPV, Tymar intake, Banks intercooler, downpipe, gauges, TW 4 position chip, John Wood Towmaster, Ford 08 diff cover, Oil gauge mod, Electric fuel conversion, RSK, OH console, Durn cat done run off an I can't find it.
It is better to have a lobster on your piano than to have a crab on your organ
joedown is offline
post #3 of 6 Old 03-28-2013, 06:49 AM
97dieselstroke's Avatar
Replace the water outlet (thermostat housing) while your at it otherwise your almost guarenteed to have a leak there. they are cheap only like 28 dollars. i have a autozone p/n for it if that helps its 815001also check if there is front to back play in the fan clutch if its much more than 1/8 to a1/4" id replace it.
97 f350 cclb 4wd xlt 7.3 e4od 34x12.5 Bfg allterrains 3" diamondeye s/s downpipe to 4" to 5" dual black turnout stacks, aux trans cooler, trans temp guage,diy 6637 intake, ts 6 pos chip. fpr shim, tc lockup switch, 10k mod
95F350 CCLB xlt 7.3 zf5 4wd 4" lift 35" procomp extreme all terrains 3" diamond eyes dp 4" straight ex. diy 6637
97 f250 eclb xlt 7.3 e4od 4wd bone stock
97dieselstroke is offline
post #4 of 6 Old 03-28-2013, 09:07 AM
Quoted: 54 Post(s)
madpogue is offline
post #5 of 6 Old 03-29-2013, 04:05 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
now is a good time to replace your belt... look into a diesel site 203 degree thermostat and housing. if u do not want to replace the neck of the pump call complete performace.... cptrucks.com... and they have a metal ring that bolts down to solve the isse of sealing problems. be aware that elc coolant is not recomended in obs trucks as the injector cups are made out of a different material then the later superduty trucks. once they are replaced its not an issue. so i would do a flush with distilled water, add a good grade diesel coolant and add 2 bottles of SCA additive. Sorry no part number.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 6 Old 03-29-2013, 10:20 AM
joedown's Avatar
I have yet to see any hard evidence that ELC cannot be used in OBS trucks. I've been using it in mine for years and haven't had an issue yet.
joedown is offline
