Orange rubberintake boot - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-26-2013, 08:05 AM Thread Starter
Send a message via AIM to mpdxtreme
While I was working on my truck I noticed that the original orange intake boot, while not leaking, was showing signs inside of splitting at the seams. Its just a matter of time before this thing splits. I understand this part is no longer available from ford. Do they offer a factory replacement or are there better aftermarket pieces available? Also I would like to replace the hoses that go to the Y pipe also, any suggestions?
Thanks
Greg G
1996 Ext Cab F250 PSD with 176xxx miles and climbing. MBRP 3 in downpipe into 4 in exhaust, EBPV deleted, AFE intake
mpdxtreme is offline
post #2 of 6 Old 03-26-2013, 08:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Riffraff diesel should have both iirc
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 03-26-2013, 08:32 AM Thread Starter
OK thanks, I'll give them a look.
Greg G
post #4 of 6 Old 03-26-2013, 09:46 AM
superduty4x4's Avatar
The boot and CCV coupler from a Super Duty are a nice upgrade.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #5 of 6 Old 03-27-2013, 11:42 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
If you want to stay factory, here's the part number for the upgraded "kit" (all hoses, breather adapter, clamps, & hardware):
Turbo Intake Hose (Black Updated Hose Kit)
(Ford) F7TZ-9C681-AA
Get it from some place like Tousley Ford Parts online (unless you actually get good prices at your local dealer). Cheers!
Patrick Feeley is offline
post #6 of 6 Old 03-27-2013, 11:45 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Or Autofair Ford!
2000-7.3L is offline
