SMOKE - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-25-2013, 08:03 PM Thread Starter
97 F350 Honeybadger33's Avatar
SMOKE
Why do some stock OBS PSD smoke more than others?
97 F350 Honeybadger33 is offline
post #2 of 9 Old 03-25-2013, 08:06 PM
boozinag's Avatar
Poor tuning, bad injectors, other mechanical problems, immature drivers.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 9 Old 03-25-2013, 09:13 PM
svranger25's Avatar
the cali version trucks are probably different cause of the injectors
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #4 of 9 Old 03-25-2013, 09:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Yeah mine smokes but has larger stock injectors and tuning, but my turbo lights faster :
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 9 Old 03-26-2013, 02:22 PM
HCSTROKER11's Avatar
Here is probably a dumb question but how do you know if you have a Cali truck? I have heard it says it on the valve covers but idk
1997 f350 4x4 off road.
353k miles
Stage 1 swamp injectors. TS chip. Leveled on 35" Federal tires and black 18 inch pro comp wheels
3" downpipe into 5" straight pipe 6" tip. (Diamond eye)
1987 Chevy 1ton lifted 24 inches on 53s. Duece and a half transfer case. Mud truck.
HCSTROKER11 is offline
post #6 of 9 Old 03-26-2013, 11:35 PM
jjones96's Avatar
X2↑↑↑↑↑↑↑↑
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #7 of 9 Old 03-26-2013, 11:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
On the passenger side valve cover there is a sticker with light blue writing, informs you it has 30 more hp, and conforms to California emissions, another way is the glow plug relay will have a "shunt" in the middle of it, and if you remove the valve covers, the injectors are ab code, also afaik the PCM in my California model is mme2, so auto and 4x4 with split shot programming
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 9 Old 03-27-2013, 07:27 AM
superduty4x4's Avatar
Valve covers can be swapped or painted over, the late 96 CA emissions trucks don't have a shunt, pulling the valve covers and/or PCM is a waste of time.
The EASIEST way to tell, by far, is if you look under the turbo there will be a round black disc (looks similar to a hockey puck) right behind the fuel pump. If your truck has this part, you have CA emissions. If not, you don't.
AB injectors on stock tuning will not smoke unless there are other things wrong with the truck.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #9 of 9 Old 03-27-2013, 08:45 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Ab injectors on a non Cali model will run poorly without tuning as well
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
