battery dumby light wont go off - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-25-2013, 04:16 PM Thread Starter
stroken96's Avatar
96 PSD with battery dumby light that wont go off. I just put new batterys in it a month ago and a new alternator like a year ago and the volt gauge reads the same as it alway has with the gauge readinf on the M on normal. any suggestions?
stroken96 is offline
post #2 of 7 Old 03-25-2013, 04:22 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
bad connection on the alt.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 7 Old 03-25-2013, 04:33 PM Thread Starter
stroken96's Avatar
Just in one of the plugins?
post #4 of 7 Old 03-25-2013, 04:54 PM
the baconator
Quoted: 153 Post(s)
more than likely the single plug on the left of the alt as you look at it from the front. i broken the plastic part of the clip of and squeeze the crimp spade connection a little bit and mine stopped flashing at me.
or your new alternator could be bad
post #5 of 7 Old 03-25-2013, 04:56 PM Thread Starter
stroken96's Avatar
Ok will try thanks for the help
post #6 of 7 Old 03-25-2013, 09:14 PM
I read a while back about having a bad diode in the voltage sensing part of the circuit that gives you that warning light can cause it. Which means you can replace it or just don't worry about it.
tucker0104 is offline
post #7 of 7 Old 03-25-2013, 09:24 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Confirm voltage with a volt meter, before you chase anything
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
