Engine running cool? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-24-2013, 03:41 PM Thread Starter
Hey guys,
Just wanted to post this to hopefully help others out. I noticed that my coolant temp (on cluster) was just above C (first line) constantly, even if I was running for an hour. For some reason I didn't think this was right. After further investigation I found a page explaining the importance for a diesel to maintain a decent temp in the engine, especially ours seeings as the injectors use the high pressure oil (and electric) to fire them. If this was the case then "cold" oil wouldn't make the injectors fire as efficiently, makes sense right!?.
I came to the conclusion that I was going to spend the $18 for a new Tstat. When I removed the one installed, I found that it was made in Germany and had a few rubber seals on it that were in very poor condition. Swapping it out with a US brand for no more than an hours work at very little cost.
Now my coolant temp gauge is constantly around the "R" of the "normal" in the range. I can also safely say that my engine hasn't ever felt this good since I bought the thing! I feel as if I am getting more power and more mpg.
I hope this thread helps others out, I'm not a mechanic by any means but with a little help and looking on other sites/pages it brought me to these conclusions.
Here is my other post.
Coolant gauge indication
My coolant gauge before.
Coolant gauge now.
Sorry for sideways photo! LOL
Rob73 is offline
post #2 of 6 Old 03-24-2013, 03:47 PM
jesilvas's Avatar
Quoted: 3 Post(s)
It's also the fact that with a warm motor, you get a more complete combustion of all your diesel.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 03-24-2013, 04:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mine looks like the second pik when I'm loaded, but unloaded it takes forever to get up to the o in normal
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 03-24-2013, 06:28 PM Thread Starter
Good call Jesilvas!
I went camping the last summer with a loaded truck, not knowing my tstat was screwed (stuck open), just thought the cool air was keeping the temp down and mine was the same as what you are saying. however, going up one of the many mountain passes here my temp gauge climbed to the "M" of normal.
So similar "problem" as yours, you might be worth looking at spending that $20 and 1 hr work to swap it out?
Rob73 is offline
post #5 of 6 Old 03-24-2013, 06:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Possibly, but I get 20 hwy on summer fuel and 16 on winter, so i don't wanna tempt fate and end up worse lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 03-25-2013, 06:48 AM
HCSTROKER11's Avatar
Yeah I'm having the same problem. My gauge only gets to the N on normal. And it fluctuates below and a little above the N. could my thermo stat be open? When I got the truck about 3 months Ago the guy had just replaced it
1997 f350 4x4 off road.
353k miles
Stage 1 swamp injectors. TS chip. Leveled on 35" Federal tires and black 18 inch pro comp wheels
3" downpipe into 5" straight pipe 6" tip. (Diamond eye)
1987 Chevy 1ton lifted 24 inches on 53s. Duece and a half transfer case. Mud truck.
HCSTROKER11 is offline
