1997 keyless entry, need help. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-24-2013, 04:32 PM Thread Starter
strokin95style's Avatar
My 97 crew cab had a cracked dash bezel when I got it. I finally got around to swapping it out yesterday and found this:
Is this factory and what does it take to make it work? Right now the rear doors do not work with the switch, only the front. I'm not the greatest with wiring so could someone lead me in the right direction on where to start on these issues? Thanks in advance guys.
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #2 of 4 Old 03-25-2013, 08:24 AM
superduty4x4's Avatar
All you need is a key fob and the directions to program it, which can be found here by searching or are sometimes included when you buy a key fob. Key fobs are $10-20 on Ebay.
Rear door problems are most likely broken wires, it's a somewhat common problem but I can't recall exactly where the issue usually is. A quick search of the forum should shed some light.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 4 Old 03-25-2013, 08:30 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Search rke on obs and bill did a full write up on it, but it has nothing to do with your windows
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 4 Old 03-25-2013, 08:35 AM Thread Starter
Thanks guys!
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
