Turn Signal
Has anyone had the left front turn signal stick on? It only does it when the cab is cold about 25ish or lower and then it takes a while to warm it up to shut it off. About 20-30 minutes of driving will do it
. Only the left front turn signal and the in dash light will flash. Once i think its warm enough for it to go off i wiggle the signal lever and itll go off if it is ready to. Has done it forever. Any input on what it might be from would be great! |
Sounds strange to me. Here in Utah it's a freezing 10 below. When it gets this cold, my right blinker wont work. When it gets warm it does
the truck will always work its butt off though no matter what
Had similar problems when servicing my buddies oversize escort trucks, as the switch ages, parts wear out, and if there is some wear/play in the lever, it will drop down enough to start making connections. You probably will need to replace the multi-function switch
